Question about FIRST Home Security
Don't have my manual. Plugged it in for first time in years, after a couple of days it went off with a steady alarm. what now?
Not a surveillance camera question! it is carbon monoxide detector
  • 1,511 Answers
Why in the world are you using this site category for the wrong issues?
Posted on Apr 16, 2015
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
NOTIFIER SMOKE ALARM PROBLEM WITH CHIRPING ALL NIGHT
Could be time for a battery replacement unless these units are hardwired
Dec 14, 2012 | Honeywell Notifier Sib-2048 Fire Alarm...
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
Siren is going off and I don't know how to stop it. It was installed about 9 years ago and installer went out of business. I think it is wired separately from the security panel. We are clear across...
Time to install another alarm system.Go to the power source just disconnect the battery power source,if the control panel don't acept the codes or respone to the codes anymore.If the alarm keep going off the police come out more than one,they'll give a ticket every other times they have to show up to check around.
Jun 05, 2011 | Ademco 1 Wave 2 Alarm Indoor Siren Vista...
Turn off daily alarms
Sounds like a trouble alarm. Try this manual page 39. Hopefully this is the type panel you have if not let me know of any writing, model numbers etc that could help me identify the specific panel.
http://www.gesecurity.com/portal/GESDownload?ID=4261&DID=4251&documenttype=User Manual
May 24, 2010 | GE Security Simon 3 Wireless Home Security...
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Feb 03, 2009 | Viper Security and Remote Start System...
Alarm Purpuse
Many parents don’t consider it a necessity since their reasoning is that their children don’t use the pool unless they are around. What is worse, many of them place a fence around the pool considering that it will give enough security. Although that is true, someone may have left the door unsecured or the child may have found an access that a grown up wouldn’t have noticed. Unfortunately, children are very curious, and can escape the attention of a distracted parent who went to answer the phone or felt asleep under the sun. It only takes a couple of minutes for the inevitable to occur. So, a swimming pool alarm isn’t only a system placed for those moments when you are not around, but a complement to eliminate the human risk factor. A machine is capable of doing what we can’t: perpetual surveillance. Like it or not, we humans are more prone to make mistakes than them.
Aug 27, 2008 | Smart Pool Aboveground Pool Eye Alarm with...
Equity 44100 clock radio problem
Hold the Alarm Set button down for about 5-7 seconds. The year will flash. Skip the year and date by pressing Alarm Set a couple times until the time is displayed. Use the Up and Down to change, then press Alarm Set one more time to save it. This clock is ****, by the way. I run into them in hotels and it makes me nuts as well. Very non-intuitive.
On the time lost issue...there is a button battery (CR2032) in a compartment underneath. That battery keeps the internal time so when the clock is plugged in, it "instantly" sets the time. Problem is, if the internal time is set wrong, then it instantly sets the wrong display time when it it plugged in. See procedure above to correct that.
Jun 10, 2008 | Equity Time USA Sky Scan 44100 Clock Radio
Home Security Logo
59 people viewed this question
Top FIRST Home Security Experts
ray gallant
Bill Boyd
Talent Magnifer
Talent Magnifer
Are you a FIRST Home Security Expert? Answer questions, earn points and help others
