Question about Refrigerators
Ice crusher won't work - Refrigerators
  • 1,511 Answers
The mechanical device is compromised. If the augers gear or rotational shaft has been damaged, it will fail to operate. Pull the entire system from the fridge and inspect the mechanical parts, shaft, gears, pins, and bearings.
Posted on Apr 16, 2015
Ice cusher not crushing
Just maybe, but do you use the same switch? If so, try using another switch, or, your ice crusher machine could be broken, the engine inside it could be water logged.
May 22, 2013 | Kitchen Appliances - Others
Tpx27pr ice crusher not working
CHANGE AUGER MOTOR ITS BEHIND THE ICE BIN
Jan 17, 2013 | GE Refrigerators
Ice crusher quit won't crush ice
Your ice crusher might be broken. I would call your manufacturers hotline and tell them and if you still have a warranty on the fridge, they should come fix it right away.
May 18, 2011 | Refrigerators
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Siemens Refrigerator model KA58NA70NE The ice maker section is not working. Please advice how to fix it.
I had the same problem and fixed it by changing freezer fan found underneath the freezer inside body, just behind the ice delivery/crusher motor. You need to open all the inside upper components like ice dispenser, ice maker, ice crusher motor, lamps assembly and finally the rear upper inside body cover. First, check whether or not the fan has strong air ventilation before trying to change the ice maker fan motor.
Feb 04, 2011 | Siemens KA62DV50GB Side by Side...
MODEL FFS26ZRG THE ICE CRUSHER CHURUSHES THE ICE
there might be something in between the door and the ice crusher. If you could check what it is, would be good otherwise call in a repairman to work on this problem.
Jun 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
Had to disassemble ice crusher and lost order of reassembly
go to web sight . www.apdepot.com. put in your brand and model # look at the ice maker bucket assm. this will give you a picture af the proper assembly . pt # 12517801 .. **** .
Jan 05, 2010 | Refrigerators
Ice crusher does not turn
KSCS25FKSS is the model you posted under is this the correct model number.If so the motor should be behind the panel directly behind the ice bin inside the freezer.
Sep 24, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice crusher don't work
Hi, It sounds like the selonoid that shifts the auger is not working. This part is located behind the panel that the bucket pushes against. The little wire arm on the bucket goes into this. Sometimes they just get froze up from the moister. If you remove the panel/section the selonoid is in, you can see if the part has went bad.
I hope this helps you. Please let me know If I can assist you further.
Vic
May 23, 2009 | Maytag MSD2650H Side by Side Refrigerator
NO ICE AND IS MAKING FUNNY NOISE
I also have the same model as you. My problem with the ice maker has been build-up of ice under the cube pan which holds the crusher and cubes. ( I pulled the pan out and cleaned up the ice, pushed and re-seated the pan against the back of the freezer where it connects into the crusher motor). In a day or 2 it was working fine again. I got this problem because my son was pullying the pan out and emptying all the ice-cubes into his cooler for his bottles of water and soda., He was not pushing the pan back far enough to seat into the motor of the crusher and this left room for the ice to accumulate under the pan and pushing it forward away from the crusher motor which makes a loud noise when the pan is not seated correctly. There is another problem I had because the freezer was opened to often. The door dispenser became warm and the crushed ice accumulated in the dispenser and froze there, so if I opened the door, ice-cubes would fall out of the pan all over the floor. Also check the back of the pan where the crusher connects to the motor, mine was full of frozen moisture turned to ice which kept the crusher from seating properly. If this is not your problem then I would call a repairman as doing it yourself can be expensive because you may buy a part and then find out the old one was ok and it still doesn't work. Ice maker parts are very expensive .If you are positive that you know what is wrong then by all means fix-it. Also check your frozen food if it is frozen solid or soft, you may have a completely different problem than the ice-maker. Hope I helped some.
                                                     Jerry
Sep 06, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
