Unable to start. Only used about 8 times since purchased last year
  • 1,511 Answers
May need updated drivers.
Posted on Apr 16, 2015
How to reset unable to clean 50 on dcp-j125
Try to reset Purge, it just might help.
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Clean unable 46 error on dcp 135c brother printer
Jun 03, 2014 | Brother DCP 165C Compact Color Inkjet...
Motherboard
I would think its a mother board problem. it could also be a processor or ram problem, as its 8 years old i would think its lasted a good long time. there are meany reason for the motherboard to start to play up. they have smd capacitors inside and over time they wear out and start causing problems or regulator chips for voltage start to wear out. it could even be that its just old. you have done well to have one last 8 years. most you would get 3 to 5 years. so it was well made for its time.
Jul 01, 2017 | Sony VAIO VGN-NR385E Laptop
Wont start was working good i clean it down went to start just wont it was parked up for 8 years we changed plugs changed oil checked timing it is good i feel the carurator have a problem
Carburator or
OLD FUEL if you have not started it in the last 8 years. TRY spraying Ether and see if it will start. This will give you a place to start
Apr 10, 2013 | Cars & Trucks
Brake rotor wear. why do the rotors have to be replaced so often. less than 2 years
Brake rotors absorb a tremendous amount of heat causing them to warp over time,,there are places who re-turn rotors using a metal lathe (where State Law Allows) turning of rotors cost from 10 to 20 dollars depending on stations,A good quality rotor made on composite metals usually lasts far longer than yours are apparently lasting
Jun 07, 2012 | 2004 Renault Megane 1.6
Unable to clean
unable to clean mean the waste ink counter need to be reset.. and the porous pad need to be replaced.. to reset ... press the Menu & Mono start keys then next press the up arrow key 4 times to make the machine enter the maintenance mode. Once in, enter 8 & 0 by using the up arrow key & SET keys. then press the mono start key several times untill the purge count appears on the LCD.
Then enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero. Last press the stop/exit key to return to the initial stage of the maintanance mode.
To exit enter 9 twice by using the up arrow & set key's to exit from maintenance mode.
May 27, 2010 | Brother DCP 115C All-In-One InkJet Printer
No use last year and stored with gas in tank now unable to start
The gas went bad in the carb, and probably clogged the carb jets. It may be necessary to remove the carb and soak it in carb cleaner. And carefully clean out the jet passages with a small wire.
May 20, 2010 | Troy-Bilt Pro-Line 160cc FRT Tiller
Have a 08 acadia with Nav. Problem started with
hi i don't know how many miles or time frame this is but this might be helpful
Updated Warranty and Goodwill Exchange Program for Electronic Products - (Feb 25, 2009)
like my car is a 01 grand prix the cat convertor was warranty 8 years they updated to 10 years
give the dealer a call
good luck
Nov 12, 2009 | 2006 GMC Acadia
Norton antivirus is unable to do live updates
Go to symantec.com, if you renewed, symantec usually sends you an upgrade to your antivirus to your email so you can update to the current antivirus software
Dec 05, 2008 | Computers & Internet
Brother 115C printer says no ink when plenty.
i bought new inks and inserted them , when in fact its only the yellow inks is empty yet it sends me message that found no cartridges.. waah. this printer been with me for 8 years and had it clean last year only.. what to do?
Jul 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
Sharp Carousel Convection Oven. Model R-9H54.touch pad
It depends on what you mean by "a problem with the touch pad assembly".
If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
These units did indeed last a long time.
Sorry I can't bring better news.
Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
26 people viewed this question
jasbo
jasbo
