Question about Samsung Televison & Video
Samsung HL-s6167w that does not turn/remain on
I have a Samsung HL-s6167w DLP TV that does not want to turn/remain on. If there are no live connections (cable, game system, ect.) it will occasionally turn on, to the "No input found" screen. As soon as any input is turned on though it will shut itself off and flash all three front lights. Prior to this, both color and brightness seemed fine. I replaced the lamp once about 7 months ago. I've already pulled it apart once and I can't see anything wrong with either the lamp or colorwheel. However, for a long while it has had a very faint whining whir, like a thin metal wire pressed against fan blades (though this doesn't coincide with either of the fans running). From what I can find it seems like my colorwheel's bearings might have gone, can anyone confirm this?
    Master:
  • Samsung Master
  • 688 Answers
That whining whir sound you hear is most likely the color wheel bearings. You can spin it by hand & listen very carefully, if you hear any noise from it, replace it.
part# BP96-01579A
https://www.encompassparts.com/item/6729532/Samsung/BP96-01579A/Assy_Color_Wheel_P
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-BP96-01579A.aspx?gclid=COHq2eSNm8UCFZOLaQodQY8AhA
https://www.youtube.com/watch?v=dnYTSeN3M3Q
Posted on Apr 29, 2015
SOURCE: samsung hlr4667w dlp tv
http://fixyourdlp.com/blog/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter/
Posted on May 28, 2008
  • 31 Answers
SOURCE: TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Posted on Aug 14, 2008
  • 1694 Answers
SOURCE: My Samsund DLP Rear Projection TV keeps turning itself off.
solder bad connections on power supply pcb.......T.
Posted on Dec 17, 2008
  • 98 Answers
SOURCE: Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Posted on Mar 03, 2009
SOURCE: Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Posted on May 03, 2010
Changed Lamp on HL-S6167W now comes on only 1-2 seconds then off/3 blinking lights
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 07, 2014 | Samsung DLP HL-P5663W 56" TV
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Dec 05, 2012 | Samsung HL-S5087W DLP TV
I replaced my lamp on my dlp samsung and my tv is not working still? i have a 65" hl-s6167w. my three led's on the front(timer,lamp,and stand by/lamp are still flashing
next step would be to replace the ballast for the lamp and the power supply board. samsung recommends replacing both components together. can call 1-800-samsung for nearest service center.
Dec 09, 2009 | Televison & Video
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
SAMSUNG DLP HL-S5086W
check the horizontal transistor if, good.re solder your tv.
Sep 28, 2008 | Samsung DLP HL-P5663W 56" TV
Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
201 people viewed this question
Jerry Greenberg
Jerry Greenberg
