Question about Exercise & Fitness
Went to go on the treadmill this morning and it's says lub belt? How do you do that?
  • 1,511 Answers
That is the traction device attached to the drive motor. Not the belt itself. It is a mechanical part that can only be accessed from within the housing and requires a technician to assemble or disassemble the unit.
Posted on Apr 16, 2015
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
I am getting power but the control board is not functioning in my ct100 model threadmill
1) make the LUB in the deck belt treadmill use wd-40 read your owner manual.
2) test the input voltage terminal in your motor, if there ARE the motor is faulty.
3) test the output voltage control board, for input voltage terminal motor, see my personal TIPS for motor HELP, if there ARE NOT the board is faulty, see the diagrams attached.
God bless you
Nov 29, 2013 | Exercise & Fitness
T9200 simple belt moved and is bunched in center
please follow this steps and fix it. GOD BLESS YOU
Nov 21, 2013 | Vision Fitness T9200 Simple Treadmill
My a2350 treadmill just stopped working - console and motor stopped
plealse LUBE the deck belt + rollers bearing too . you must do it after 150 miles aprox.
2) adjust the REED switch see the diagram, clean it, test for open or faulty. Tight the connector very well.
Jan 25, 2013 | Nordic Track NordicTrack A2350 Pro...
How do i lub the belt
Loosen the walk belt by loosening the two adjuster bolts at the rear or the belt a couple of turns. Take your oil and reach your hand under the belt and smear the oil on the smooth board under the belt. After tighten the bolts, start the treadmill and adjust the side to side on the walk belt. The oil will coat the back of the walk belt and you are done!
Hope this was helpful.
Jul 28, 2011 | Exercise & Fitness
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
Belts are ok but there is a lot of squeking is there something i can do to stop this
You can start by spraying the belts with Belt-lub which can be purchased at any auto parts store; the lub will also extend the life of the belts. Also check the adjustment to see if the belts need to be tightened.
Mar 17, 2011 | Chevrolet G10 Cars & Trucks
CONVEYOR BELT NOT MOVING ON THE IMAGE TREADMILL
This could be because the belt on the motor that turns the belt you walk on is worn out. it has grooves on this belt that must be prominant to stay in the groves on the front roller and motor. The motor belt can be ordered for about 20$ shipped on ebay the motor belt number is 118016 this is a universal belt and fits this treadmil. Before buying the replacement belt check to see if this is for sure your problem. you can tell by opening the front of your treadmill and looking at the belt. You will see worn spots on the motor belt, or as I noticed when mine went bad, it will look like someone threw a bunch of rubber eracer shavings in your treadmill.
Aug 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Treadmill stck in upgrade
need to lub it oil whatevever makes it escalade up and down
Jan 24, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Exercise & Fitness Logo
46 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
