Question about Tefal Actifry Family Ah900015 Low Fat Electric Fryer, 1.5 Kg Capacity, White
Video in how to replace heating element in actifry
Still rotates but does not heat up
  • 1,511 Answers
In most cases the coils are more expensive to repair and replace than a new unit would cost. May be worth investing a new system.
Posted on Apr 16, 2015
Where do I put the filter
On the Actifry and Actifry Plus models, the wire grease filter sits in the recess below the fan intake at the back of the machine, just under, and in front of, the heating element. Once in place, push it back against the fan grille and the clip on the plastic filter holder will keep it in place.
On the Actifry Family the filter is in the same place, but slides into two grooves on either side of the fan intake, and doesn't need clipped into place.
Oct 06, 2013 | Tefal ActiFry Deep Fryer
Element stopped working
Replace the element. Search Amazon for your actifry model number and you should find the spare parts for it.
Feb 18, 2013 | Tefal ActiFry Deep Fryer
Tefal actifry paddle will not rotate
Replace the paddle motor. Spares are redily available on Amazon
Mar 28, 2012 | Tefal ActiFry Deep Fryer
My tefal actifry has stopped heating as the paddle rotates can you advise me
You have just two options:-
Return the unit to Tefal for a repair under warranty, or claim under a separate product warranty.
If you have no warranty then your only fix is to replace it with another ActiFry. But as they're notoriously unreliable you might choose not to.
There is almost nothing user-fixable on the ActiFry and it has not been designed to be repaired. They have about a 3 year maximum lifespan assuming an "average" domestic usage cycle, and far less if used every day.
Sep 23, 2011 | Tefal ActiFry Deep Fryer
HEATER COIL DOESNT WORK
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 25, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
THE TIMER IS NOT ROTATING(I CAN MANUALLY ROTATE IT,BUT IT DOES NOT MOVE WHEN THE DRYER IS RUNNING). DRYER DOES NOT PRODUCE ENOUGH HEAT AND IT TAKES LOT OF TIME (4HRS)TO DRY THE LAUNDRY.
You need to buy a new timer and replace it. Be careful when replacing the timer as there are many electrical contacts in the back of the timer so when remove it, please label all the wires. Please follow the instruction from the manufacturer how to replace the timer. Of course, make sure you unplug the dryer because the dryer is powered by 220~240 VAC not 110~120 VAC.
As for the heater, there are two possibilities. The first one is, part of the heating element is open circuit and therefore, there is not enough heat to your clothing. The second possibility is, your timer contacts is broken, when the timer asks for high heat, the electricity supposes going to all the heating elements, but since the timer contacts are broken, you have only part of the heating elements working. The heating elements are quite easy to replace but please replace the timer first. You may fix both problems once you replaced the timer. WL
Nov 15, 2010 | Hotpoint Dryers
Dryer rotates, but there is zero heat. Kenmore Series 80, model 0104806
First check your breakers in the power box to the house. If one the the legs is tripped, the cylinder will turn but will not heat. Next, check the thermostat switches near the heating element for continuity. If no continuity, replace them. Check heating element for continuity. If no continuity, replace.
Aug 08, 2010 | Kenmore 84052 Dryer
No heat it blow air and rotates
your dryer may need a new heating element.
unplug and remove the back cover.
your looking for a grey rectangular box with red
wires coming out the bottom..
undo those wires noting location, (take picture )and the safety limiter wires also.
remove the box and put it on a workbench.
you need to remove the element out of that box now. there are a couple more screws that release the inner element.
study the element and look for the break in the element wire, you should be able to spot it.
you can get a replacement element at the sears appliance store outlet in your area for around 25.00
jm
Nov 28, 2009 | Whirlpool Dryers
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Tefal Actifry Family Ah900015 Low Fat Electric Fryer, 1.5 Kg Capacity, White Logo
1,256 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
