Question about dr. Tech WA-1080PC-T Solar Wireless Home Weather Station - Links to PC
How to turn off alarm
The alarm clock wont turn off
How can I shut off the alarm on an unidentified clock radio?
Barbra; Alarm clock shut off and snooze button are not the same thing, if you want alarm off, use the slide switch, slide switch to alarm off position.
How To Set TIME ALARM CLOCK of VINTAGE Old LLOYD J375 771A RADIO AM FM...
How To Turn Off The Alarm On The RCA Talking Clock
Jan 25, 2016 | Audio Players & Recorders
How do I completely turn off the alarm on one of my alarm clocks?
Turn the alarm selector switch to off. If it still happens you have a faulty clock radio
Oct 04, 2014 | Emerson CK5052 Dual Alarm AM/FM Clock...
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
How do I turn off the alarm clock? It keeps coming on every 5 minutes
When you are in alarm setup mode the Up button Is your on-off switch
Dec 27, 2012 | Discovery Channel Discovery Kids - Rocket...
I have a Chaonei projection clock and the alarm won't turn off. There is no off button only the snooze. Very annoying.
To turn off alarm1 press button named "up" and for alarm 2 press button "down" Note: No need to press mode or set anything you just need to press the above specified buttons directly when it is normally displaying the time
Mar 26, 2011 | Audio Players & Recorders
We have a roberts cr 9977 chrono logic v radio alarm clock and we cant reset the alarm clock. What can we do
got a roberts alarm radio clock cr 9977 electric went off wont come back on what should i do .
Jan 23, 2011 | Kitchen Appliances - Others
My sony radio alarm clock is too fast about 1 hour. i have moved in the philipines. but my alarm clock is working too fast; ie, it does not show the exact time (about 70-80 minutes) faster
alarm clocks works on frequency and not only on voltage.if it is original 110v 60htz and you trying with 220v 50htz supply then it wont work correctly
Jun 04, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
Dead
check the fuses in the plug and in on the board
Sep 14, 2009 | Emerson Smartset Clock Radio
Setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
Oct 21, 2008 | RCA RP5440 Clock Radio
GE Model 7-4837B
press the Cancel button located on the top of the alarm clock (the light next to the wake mode indicator on the front of the clock should start flashing). Then press the WAKE Mode button on the top of the device. The wake mode indicator on the front should now be off and the alarm deactivated.
To turn the alarm back on, simply press the WAKE Mode button on the top of the device.
Mar 27, 2008 | GE 74801 Clock Radio
dr. Tech WA-1080PC-T Solar Wireless Home Weather Station - Links to PC Logo
135 people viewed this question
Top dr. Tech Measuring Tools & Sensors Experts
Lawrence Oravetz
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a dr. Tech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
