Question about Echo Garden
I purchased a new saw yesterday.I would like to keep my old saw. Will it be wise to purchase a used crankcase with a complete short block..if so which is more compatible with the echo cs-400.thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
It depends on how much you like to tinker around with small engines and how much money you're willing to put into a 'back up' saw.
With new saw prices nearing $700 - $800 for pro series saws its easy to justify repairing them if you're capable.
Posted on Apr 21, 2015
dontbother10
  • 2220 Answers
SOURCE: Need replacement crankcase for Echo CS-750EVL chainsaw
There are 2 complete CS-750EVL saws on my local Craigslist.
Try here for Echo IPL:
http://www.echo-usa.com/pdf/documentation/CS750EVL_010185.pdf
If not your saw:
EchoUSA
http://www.echo-usa.com/documentation.asp
Type your model number into the search window.
Good Luck
Lou
http://seattle.craigslist.org/see/tls/1571477399.html
http://seattle.craigslist.org/tac/tls/1571683044.html
Posted on Jan 27, 2010
dontbother10
  • 2220 Answers
SOURCE: No Start Echo CS 670
Sorry to echo the bad news you heard but... often metal transfer from the piston to the cylinder feels like compression. Try part 3 of this, Attempt to shine a light into the plug hole through while inspecting above the exhaust port. Most often in a run lean condition metal transfer occurs above the exhaust manifold.
Starter Handle difficult to pull:
1. Remove the starter cover.
Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots on the crack shaft and flywheel aligned and the key intact? If not; Please consider taking the saw to a good local saw seller/mechanic for a written diagnosis before authorizing any repair or ordering any parts; if yes continue.
Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
Leave the ignition off, set the valve and pull the starter.
Pull gently to release the valve. Is there a difference in the effort required?
If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
The cost of a P&C nears the cost of a new saw. Join here, search for acid and maybe you can get by with just replacing the piston. This is good bunch of folk that will offer all help possible.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
An example of a repair here:
http://www.arboristsite.com/showthread.php?t=135021&highlight=acid
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 06, 2010
  • 4088 Answers
SOURCE: Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
eugbug
  • 479 Answers
SOURCE: Brand new Echo cs-400 chain
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
Posted on May 12, 2011
Terry Corrow
  • 10875 Answers
SOURCE: Echo CS-400 chainsaw is it better to clean or replace the gaskets in the carburetor. .saw won't start?
replace,ethanol in the fuel eats rubber,try to use gas without ethanol
Posted on Apr 07, 2015
Yesterday I purchased a craftsman compound miter saw with laser trac, I used it for about a half hour and the laser is on, but not shining on the cutting surface...help!
You might have to set it to shine in the right place. There might be a small 'nipple' from where the light is shining. This can be moved. First make a cut, then set the line to shine on the cut. It might be possible that dust accumulated and blocks the light, depending on what material you have cut.
Aug 19, 2017 | Craftsman Saws
Delta 28-160 3 wheel band saw and the blade slips off after 1-2 rotations of the wheel. I have replaced the tires with the blue tires.
one of the wheels will have an adjustment that aligns the wheel correctly
bands/belts always run to the highest point so one of the wheels is not true and presenting a high point causing the blade to run off
Sep 03, 2016 | Olson Cool Blocks 5008 Delta 28-180, 160 &...
I would like to know if i can purchase a new motor complete for this model and what the cost would be
What is the make and model?? Its unusual to be able to buy a complete new chainsaw replacement engine, A lot of chainsaws have the crankcase making up the bottom end of the saw which is the majority of the complete saw by the time you've finished, However most parts are individually available
May 20, 2016 | Garden
Saw only runs with choke half open could it be the jets or what?
This problem usually comes from using fuel in the saw that has alcohol in it without adding a fuel conditioner. The saw and any other machines using gasoline must be run completely dry of fuel when storing or may sure that the saw has a conditioner mixed with the fuel. Sounds like the power jet portion of the saw is blocked. Typically the only fix is to take the carb apart and open that portion of the carb. The only way to keep this sort of problem from happening is to purchase alcohol free gasoline for your portable gasoline run machines.
Sep 14, 2014 | Echo Garden
I have a husky 235 (e = ?) & it has been very troublesome for me. My little 3000 Echo saw i purchased in 1995 (& have had refurbished once since then) outshines the husky reliability-wise. On the...
The oiling on this model has been an issue for a long time, the first and main problem was distortion of the bar pad due to heat from the muffler, and the ommision of a metal strengthener in the pad itself, what happens then is as the bar nuts are tightened, the bolts try to pull throught the bar pad, this creates a bulge around the bar bolt and causes the delivery tube to collapse, there was a later crankcase with steel inserts around the bar bolts to prevent this, and an updated delivery tube, you can tell when this has happened as the oil drips onto your shoes rather than going onto the chain, let me know it you need any more advice or i have not explained this very well, what has the dealer said about the oiling problem?
Apr 15, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Does my roadmaster 1992 have a short block engine 350 motor?
The '92 Buick Roadmaster is equipped with a 5.7L TBI 8 cylinder engine.
The 5.7 is the 350 CID. When you inquire about a "short block" however, that is not what is in your car.
A short block means only a partial engine, incapable of running until other parts are added to to complete it.
Usually a short block consists of the basic block, crankshaft, rods, pistons, and rings. Some may come with oil pump, but I think most do not. If you buy a short block, you'll have to either transfer necessary parts (heads, intake and exhaust manifolds, oil pan, oil pump, water pump, etc....) from your current engine to the purchased engine, or purchase the needed parts from a supplier. Additionally, you'll have to purchase the necessary gaskets, seals, etc. to bolt these parts on to the "short block".
This isn't a huge task, but it may well be beyond the scope of the average DIY individual vehicle owner.
If you want to pursue this, you can purchase vehicle specific repair manuals from your local auto parts store.
Whatever you decide to do.....GOOD LUCK!
Jan 16, 2011 | 1992 Buick Roadmaster
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Pole electrical malfunction
GREENWORKS 20302 G-MAX 40V CORDLESS POLE SAW is a great saw. You can easy to use. more details go to the link
Detailed GreenWorks Pole Saw Review
Mar 31, 2009 | Remington Polesaw Wizard
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Toyota Sienna won't start in -18F
I would replace the battery, purchase and install an oil filled battery warmenr, and purchase and isntall an engine block heater.
Dec 15, 2008 | 1996 Toyota Corolla
Open Questions:
Garden Logo
116 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
