Question about Husqvarna 48" Briggs & Stratton Intek V-Twin 23 hp Gas Powered Riding
POPS WHILE CRANKING AND WONT START NOT GETTING FUEL THRU FUEL FILTER?
    Master:
  • Husqvarna Master
  • 645 Answers
Some things to check: Fuel pump (if equipped) Fuel solenoid shut off, fuel lines, carburetor.
Posted on Oct 26, 2017
2005 wrx 2.0 getting fuel to the rail but not to injectors or engine. cranking for about 30 secouns causes backfire in the intake but engine wont start. what could be the problem?
Well technically you have fuel in the engine if you are getting a backfire in the intake. I would say the fuel is getting thru the injectors.
But maybe not at the right time.
Has anything happened to the timing belt or cams ?
Apr 11, 2013 | 2008 Subaru Impreza Wrx
Engine cranks but wont start, replaced the fuel filter,fuel pump works, fuel relay works, theres spark to engine
what year? if it a 350. take 12 volts directly to the distributor. if its cranking then dump some fuel down the carb. that should make it run for a little. if you are getting spark you are not getting fuel if it won't start
Sep 06, 2010 | Chevrolet Silverado 3500HD Cars & Trucks
My van wont start, it turns over but acts like it is not getting any fuel. Could it be fuel pump or filter?
did you check the spark if occur when cranking engine, if it have spark, direct fuel pump by shorting 30 and 87 pin off fuel pump relay and check if theres fuel go to fuel injectors, check for pressure, if no fuel, connect voltage directly to fuel pump assembly, if fuel turn s, check circuit, if no fuel goes, check the tank for empty fuel, if you have fuel change the fuel pump including fuel filter
Jun 26, 2010 | 1997 Mazda MPV
My 90 astro van wont start its not getting any gas could it be the fuel pump Ive checked the fuel filter
First find out if your getting power to your fuel pump while cranking. If not then you must trace where the power stops and fix that. The's a way to jumper power to your fuel pump but thats only for testing purposes you still must find what's not telling the fuel pump to turn on.
Oct 12, 2009 | 1990 Chevrolet Astro Extended
My 91 mitsubishi gto wont start and strong smell of fuel
Start by making sure you have spark to the spark plugs. If not you may have a problem with the plug wires or coil. It's also possible you're not getting gas to the engine possibly from a faulty fuel pump.
If you change the fuel pump be sure to replace the fuel filter also.
Jul 13, 2009 | 1991 Mitsubishi 3000GT
Why wont the van stay started
check the fuel pump, filter and fuel pressure from the rail
Mar 01, 2009 | 1993 GMC Safari
Wont start. plenty of crank yet wont start
Cold start injector, possibly
Dirty fuel filter or failing fuel pump
Intermittent faulty fuel pump relay
Jan 09, 2009 | 2005 BMW X5
No start
no fuel to filter you say!! when you turn key on with out cranking it can you hear the fuel pump grunt grrrr? I would start with that!!!
Jan 07, 2009 | 2003 Dodge Sprinter
Car quit and wont restart
It could be a any or a combination of failing components. If you haven't changed the fule filter recently (say within the past 20,000 miles) I'd change it first. Next. check the fuel pressure at the service port near the injectors to ensure you're getting the right fuel pressure to the injectors.
Aug 11, 2008 | 2000 Toyota Camry
Husqvarna 48" Briggs & Stratton Intek V-Twin 23 hp Gas Powered Riding Logo
120 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
