Question about Garden
Where is the location of the oil drain plug
    Sergeant:
  • 462 Answers
Bottom base plate
Posted on Apr 23, 2015
2 Suggested Answers
  • 6468 Answers
SOURCE: How do I drain the oil on a Briggs and Stratton 8hp 191702 ride on mower ? I can't seem to locate the oil drain plug.
if you follow the dip stick tube down to the base of the engine there is a square head bolt that is the drain plug
Posted on Jun 28, 2012
Where can I find the oil drain plugs on my 1989 Harley FXR? I'm doing a complete oil change. Ive looked at tons of different sites but the plugs don't match the location my bike.
Hi David, for a 1989 FXR the engine oil drains out of the oil tank via a rubber hose located at the rear bottom left corner, the transmission drains from a large threaded plug located on the bottom center of the transmission case, the primary chaincase oil drains from a small threaded pipe plug located on the outside of the primary cover directly below dead center of the clutch inspection cover. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 19, 2015 | 1993 Harley Davidson FXR Super Glide
1998 FXDL drain plug location
Hi Anonymous, the oil pan is located underneath the transmission the engine oil drain plug is located on the bottom of the pan in the front left corner. The transmission drain plug is located on the bottom on the right center side. Good luck
Apr 29, 2014 | Harley Davidson Motorcycles
Where is the trans drain plug on a 2004 harley dyna
Hi Anonymous, the oil pan is located underneath the transmission, the transmission oil drain plug is located on the bottom right hand side. The engine oil drain plug is located on the left side rear corner. Good luck
Apr 08, 2014 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
Where is the oil plug drain located on a 2010 harley wide glide ?
The oil drain plug for your Wide Glide is located on the bottom of the transmission as the oil tank is in this location. The oil drain plug is usually located at the right front of the oil pan.
Good Luck
Steve
Jun 12, 2011 | 2010 Harley Davidson FXDWG Dyna Wide Glide
Were is the drain plug located on a 2007 chevy 5.3 on the passenger side of engine . is it behind the ac unit. i want to put a engine block heater in.
The block drain is on the passenger side of the engine, in the center of the block near where the oil pan attatches to the block.
Engine Block Plugs/Sensors
100 - Engine Block
100 - Engine Block
101 - Oil Gallery Plug - Front
110 - O-Ring
111 - Oil Gallery Plug - Rear
112 - Oil Gallery Plug - Side
113 - Washer
114 - Engine Coolant Heater
115 - Washer
116 - Oil Gallery Plug - Side
117 - Washer
130 - Transmission Housing Locating Pin
145 - Washer
146 - Engine Block Coolant Drain Hole Plug
701 - Crankshaft Position (CKP) Sensor
702 - O-Ring
718 - Knock Sensor
718 - Knock Sensor
739 - Bolt
739 - Bolt
750 - CKP Sensor Bolt
Oct 19, 2010 | Chevrolet Silverado 1500 Cars & Trucks
What are the step by step instructions to change my oil in my 2008 Chevy Malibu LTZ?
Find the oil drain plug, remove, drain the oil into a pan, reinstall the drain plug a tighten, locate the oil filter and remove, check mounting surface to make sure the old gasket didn't stick. Coat the new filter gasket with oil and install hand tight. Refill the oil, make sure that you do not overfill. Start enigne for about a minute, shut off and double check the level, and that the filter and drain plug do not leak.
Some engines can be difficult, to identify the location of the drain plug and filter. There are thousands of configurations out there, If you are not familiar or can not locate the plug and filter, take the vehicle to a shop for service.
Apr 11, 2010 | 2008 Chevrolet Malibu
Oil Change
The oil drain plug is located at the bottom of the engine under the car It should be a bolt directly in the oil pan that would be your oil drain plug.
Feb 01, 2009 | 2001 Cadillac DeVille
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
