Question about Garden
My mower will start but with some effort from me .. Once up and running it will go for about 3/5 mins then dies on me and is a struggle to get going !! I have fuel running to the carb if that helps
  • 2,049 Answers
Pull the fuel bowl off if it has one and clean it real good and clean the fuel jet. May not be enough gas to keep it going a longer time.
Posted on May 03, 2015
steve_lima
  • 181 Answers
SOURCE: I have a Brigs&Straton 6.5 Quantum lawnmower will not stay running. I can keep it running by restricting the amount of air entering the carb with my finger (choking it) The mower will start if it
the problem is in your carb.,at the bottem of the carb. there is a bolt that threads in to the carb.pinch off the fuel line so that no fuel comes out after the fuel bowl is off the mower.now look into the bolt that you took off.there should be a hole oppisit the head of the bolt.there are also two holes that go through the sides.these holes are the fuel intake to the carb,the hole in the center is the fuel nozzle.most likely you have dirt blocking this hole and not letting the motor get enough fuel to run.thake some carb cleaner and spray it in the hole.take an air hose then blow the nozzle out.while you have the screw out take the bowl off and check to see if there is any water or dirt in the bowl.after cleaning.reinstall the bowl and start mower again.should be running ok now.if not let me know and i'll guide you through another fix.let me know if this helped or not................
Posted on Jun 02, 2009
  • 22 Answers
SOURCE: I have a mountfield classic 35. It struggles to
replace the carby diaphram between the tank and carby that will fix it (diaphram controls the fuel pump and when faulty can make engine rich or lean with revs impossible to control)
Posted on Jul 20, 2009
  • 10865 Answers
SOURCE: Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Posted on Sep 14, 2009
  • 2926 Answers
SOURCE: my troy built lawn mower dies after it starts runs
Your high speed needle jet is most likely the cause. Remove the jet and clean it out. Keep in mind that there may be least one or two very small holes drilled in to the sides of the high spped jet, if so, be sure they are cleaned and not clooged.
Posted on Jan 17, 2010
Testimonial: "worked perfect tks"
SOURCE: push mower starts, then dies, ad nauseum
i have a 21",4,5 hp yard machine with a briggs
Posted on Aug 26, 2010
Why does it die after running 10 minutes?
Could be 'Vapour lock' when it dies, try opening the fuel tank and see if it starts back up.! If it starts and runs fine then I would put the cause down to a faulty tank vent, which isn't allowing air back into the tank to compensate for the fuel being drawn out meaning the saw is struggling to draw fuel out the tank as its in a vacuum.
Apr 17, 2016 | Garden
Run for 15 min then dies. It was low on oil. Added oil over the full line now it runs for 3 min running rough and then dies To much oil now?
Your mower dying would have no correlation with how much oil you have in the engine. Didn't I answer this question for you yesterday?
Your problem is fuel related. Fuel goes off, so it should be fresh from the gas station every season. Check lines for kinks. Check lines for air locks. Check your fuel filter if you have one. Check that the fuel tap works properly.
Apr 03, 2016 | Garden
Kohler engine troubleshooting
Sounds like you got some dirt or rust in gas tank
try emptying the tank and cleaning it out. also check you bottom of you gas can too it could be souse of dirt in you tank.
Just remember to put fresh clean gas in mower gas tank after you clean it.
Aug 18, 2014 | Toro Garden
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
I have the 6.5 hp self propelled model, It starts fine and runs strong for aprox 5 min then dies, seems to die when it gets hot possibly, the die time is always the same aprox 5 min. Once it dies it will...
I don;t know what engine is on your mower but if it has the self contained electronic ignition coil I have seen happen on several engines. It would run good for several min. then the spark just stops . And it will not spark again until it sets and cools . Just make sure it is the ignition that is not working.
Sep 15, 2010 | Toro Lawn Mower With Toro Power Tools
Troy-bilt self-propelled w/briggs and stratton 6.75hp after starting runs for 3 or 4 mins. dies out and in 3 mins later will start and do the same thing any suggestions?....thanka abb
Hello. Your carburator is partially clogged up. That said, if you havn't installed a new fuel filter and new air filter this year do so. Also put in a new plug if u havn't lately. Finally get a bottle of a fuel additive called seafoam and pour it into the fuel following the directions on the bottle. J.
Aug 16, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Ride on mower drive problem
sounds like a belt to me not tight enough against the pullys
Nov 09, 2009 | Mtd Gold 42" Zero-Turn Mower -
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
