Question about Garden
Valve adjustment Has getting in oil
  • Steve Birdwell
    Steve Birdwell Apr 18, 2015
    24 hp Kohler on zero turn Husquvarna has gas getting in oil plus need to know how engine valves on motor tha gap with feeler gauge should be on intake and the exhaust vales
    Top Expert:
  • Garden Master
  • 51,126 Answers
A better description of your problem is required as what you have so far doesn't make too much sense.
Posted on Apr 19, 2015
I have a 2008 Ford Expedition and it’s making a bad knocking noise. Someone told me it’s the lifters and that it will readjust on its own. They had me add some Lucas oil treatment to the oil and said that...
Sounds to me like the lifters are ticking when the cams hit them. This generally means you need a valve adjustment. Sometimes, in rare cases, it can be caused by an UNDER performing oil sender, or low oil pressure and not enough oil getting to the top of the motor. I would check the output on the oil sending unit first, if that checks out, have a valve adjustment done and it should go away. It's also worth me noting here that I've had super BAD experiences with putting ANYTHING other than actual engine oil in my vehicles. It seems all these "additives" end up doing more harm than good. Change the oil to eliminate that Lucas junk, and get the oil sending unit checked, and valves adjusted properly.
Dec 13, 2017 | Ford Cars & Trucks
What does base circle area mean when doing a valve job ?
Base circle is the camshaft lower diameter where the lifter rides before the lobe starts to come into play.
The Lost Art of Valve Adjustment
Your second question depends entirely on the engine in question.
On a pushrod V8 the oil usually is metered by the valve lifters and goes to the rockers through hollow pushrods; a few drops of oil are released by the lifters during each valve stroke. Until full oil pressure and warm oil are in all of the oil passages, the oil to the rockers will be less than that of a warm running engine. The rockers really don't need huge quantities of oil, it is a lot harder to get oil to the valve stems.
You may want to make sure you have good oil pressure and the valves are properly adjusted [even on a hydraulic lifter system there are limits to how much the lifters will self adjust].
If you have an overhead cam engine, you will need lots of oil on the lifters and cams.
Feb 06, 2015 | Cars & Trucks
Audi a4 1998 tapping noise only when idles under valve cover
Sounds like a bad valve lifter or a valve out of adjustment. It's probably a bad hydraulic valve lifter. In idle, when the oil pressure is lowest, it is not filling with oil. When the motor revs up, oil pressure rises and fills the faulty lifter.
If you do have mechanical lifters, the valve is probably out of adjustment. If you do car work, pull the valve cover and see if it's adjustable. Of course, you'll need the specs from VW/Audi.
Otherwise, it's probably a shop job.
Sorry.
Jul 05, 2014 | 1998 Audi A4
Ticking noise on a Yamaha motorcycle
Most likely what you are hearing is a slightly loose rocker arm clicking when it contacts the valve. Even when they are adjusted properly they can make some noise - depending on the condition of the engine oil and the temperature of the engine. You might look into having your valve clearance checked and adjusted. Change your oil if you haven't recently and you might consider running a heavier, synthetic oil - especially if you have more than maybe 30,000 miles on the engine.
Realistically, you should have the valve clearance checked/adjusted every 15,000 miles and you oil changed every 4,000-5,000 miles max for synthetic oils, less for conventional oils.
Jun 27, 2011 | 2001 Yamaha V Star 1100 Classic
Im hearing a clicking noise while accelerating in my 2001 chevy s10 4cl 2wd automatic
Is the clicking coming from the engine? If so you might have to do a simple valve adjustment. How is the oil? If your oil pump is getting weak, it could cause it. Pull off a valve cover, and see if oil squirts out when you hit the gas. If it is a valve, you can hear it when you pull the cover, and adjust it till it stops. You might also have a weak lifter, It happens after the vehicle gets some miles on it, simple to replace. hope this helps
Jun 08, 2011 | 2001 Chevrolet S-10
My valves are ticking on my 97 doge 2500 pick up it has the 360 magnum can i adjust them or not .....
Ticking sound is normal from a health diesel engine is normal.
Diesel engine that does a lot of towing or carry large payload can use a head adjustment every 2 years or 24,000 miles.
I would keep tabs on the valve cover for oil leak.
Take it in the shop when the valve cover start to leak.
Do the valve adjustment,the valve cover and oil change at the same time.
Shell ROTELLA T Multigrade SAE 15W-40 is my prefer motor oil.
Nov 06, 2009 | 1997 Dodge Ram 2500 Club Cab
While running engine runs hard. Also tapping or ticking sounds after installed new oil pump ,pan and gasket. I've been told is the lifters. So Ive tried lucas oil stablaizer, Mystery oil and CD2 still...
If you have an adjustable valve train you may need to adjust the rocker arms. Remove the valve covers and look to see if there are adjusting nuts on top of them. If so, get a shop manual and a feeler gague and a couple of wrenches and screwdriver and follow instructions in manual carefully.
May 20, 2009 | 1986 Mercedes-Benz 300
New rebuild chatters
adjust your valves your oil pickup tube needs to be adjusted you need feeler guages to adjust the valves down properly
make sure lifters and oil pick up tubes are not clogged
feeler guage is---> thin pieces of metal cut to different sizes to hold under valve adjusters till the play and chatter gone
check by book what the feeler size needed for adjustment
Jun 07, 2008 | 1983 Chevrolet C3500
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
