Question about Plumb Pak Actuating Lift Chain Fits American Standard PP830-46L
How to install? different than any I've used. have plumb ball stopper
Moen drain adjustment
there is a rod under your sink which controls the travel of the stopper it needs to be adjusted for shorter travel.
Aug 26, 2017 | Moen Plumbing
Tip
How to make an inexpensive "shelf" for books
Plumbing piping can actually be used <i>outside</i> of the walls. I've seen and done things myself using metal plumbing piping as decorative yet effective tools. I've seen them as curtain rods, lighting fixtures and legs for tables.<br>My favorite, though, is screwing them into walls and using them as shelves for books. You can make all kinds of crazy patterns and designs using extensions. Google plumbing and shelves. See what you find!
on Jul 18, 2013 | Furniture
Bathtub spring stopper has no rocker arm or stopper. Where do I find the parts and instructions on how to install correctly.
Your best solution for this is to contact a plumber or someone at a local plumbing wholesale store.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Home
Water oozing from top of my Everhot electric storage system where there is a rubber stopper. Can I fix this myself?
1) Bradford White posts some Operation manuals, and troubleshoot guides for electric tankless units:
1-800-334-3393
http://www.bradfordwhite.com/documentation/residential/electric.asp
2) For gas:
http://www.bradfordwhite.com/documentation/residential/gas_tankless.asp
3) I do not know of a rubber stopper used for plumbing or tankless.
4) Call service technician.
Jan 02, 2013 | Water Heaters
The rubber washer on the stainless steel plug has perished and therefore will not hold water in sink when needed.
Unless its really old, you should be able to find a replacement stopper at HD or local plumbing supply.
Apr 30, 2011 | Blanco Sink Waste Strainer / Stopper...
The instructions say remove the stopper ...only the knob comes off
Pull it up with the knob in place and under the stopper for set screw to losen and remove.
Feb 01, 2011 | Plumb Pak Roller Ball Tub Drain Assembly,...
I removed the plug on my American standard lifetime drain and it won't close now. I can't get it to hold water now. I can't find any diagrams to show how the plug should be configured to help solve the...
You have to take apart the "drain rod" assembly under the sink. There will be a rod with nut on it that goes into the drain near the sink. Take the nut off, drop the stopper in with the eye hole towards the wall and then reinstall the rod through the eye on the stopper and tighten the nut.
Oct 22, 2009 | American Standard Lifetime Drain, White
Replacement Reebok Gym Ball Plug/stopper
We have these for sale on eBay now:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230524179989
Apr 24, 2009 | Reebok New York Giants Eli Manning Jersey
We are installing a plastic bath tub drain, but, the barrel stopper leaks. This is brand new;I have sanded smoothed the barrel with no improvement. Any ideas? Ed
barell stopper, trip lever? is this the same thing? If so go and get a push pull waste and overflow and forget the trip lever, (old school stuff).
Mar 29, 2009 | Mountain Plumbing MT406 Bath Trap...
Plumb Pak Actuating Lift Chain Fits American Standard PP830-46L Logo
379 people viewed this question
Top Plumb Pak Home Experts
Donni Steen
Tom Chichester
Are you a Plumb Pak Home Expert? Answer questions, earn points and help others
