Question about Singer Sewing Machines
Need to know how to thread bobbin on singer 1411
  • 1,602 Answers
I'm trying to load my bobbin on my singer 628 and the bobbin doesn't wind. Any ideas?
Anon, Found links to help with bobbin does not wind, make sure to read the articles in the forums, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://ca.answers.yahoo.com/question/index?qid=20070630202938AAGRwx2
Singer 628 Touch and Sew sewing machine manual smm043 Machines name begins...
Thread Singer 628 Touch and Sew Questions
Apr 05, 2016 | Singer Sewing Machines
Singer 404 - The top needle thread will not pick up the bobbin thread on a Singer 404. I know the timing is fine, the needle is in correctly and I have loaded the bobbin thread correctly. I don't know...
is it the original bobbin? try a different bobbin, sometimes they won't work if slightly dent or chip! I know it sounds weird bt it's the truth about bobbins
Nov 14, 2013 | Sewing Machines
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
Singer featherweight bobbin won't pick up needle thread
pull the bobbin case out by pulling tab or flapper forward (outward toward you) and take bobbin out of bobbin case, If bobbin has thread and that it is coming off bobbin free and is not hung up on bobbin case.
let me know if this helps you,
sec_duane@hotmail.com
Nov 10, 2007 | Singer Featherweight 140Q
Sewing Machines Logo
59 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
