Question about Radio Communications
Can I connect my Bluetooth earpiece with my Safelink phone?
  • 1,602 Answers
Check the driver to up to date
re install software, but you must remove the old first so you will not continue to have the same issues
can you try sync the devices
you have to look at all anti virus programs and firewall settings
make sure you have fresh batteries in the head phone if the take them.
check the setting in the phone, go to settings than to account & sync
check application setting as well
make sure the program is not already running, look at manager applications also, than also look in the location and security setting under wireless networking
you also need to check the wireless and network settings,make sure the blue tooth is turned on
check the voice input and output section also
need to look on phone see if you 4 little dot on the lower side on either side of the lowest screen move your finger across the screen the screen should move that direction keep moving it until you find display of devices that are running to make sure the blue tooth is high lighted show that the device is on
Posted on Apr 16, 2015
SOURCE: Earpiece
with mine, all I do is hold the top button down for about 8 seconds until I hear a tone/beep. Then have my phone search for an audio device and it picks of the earset and ready to go. I hope this helps.
Posted on Apr 05, 2008
  • 3 Answers
SOURCE: after charging earpiece my phone will not connect
I found the solution in the online manual from motorola. I have included the website below: http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Posted on Aug 18, 2008
SOURCE: BLUETOOTH HEADSET
Obviously a compatibility problem. Bought a new headset!
Thanks for trying
  • 3 Answers
SOURCE: bluetooth connection
You need to set both your phone and the headset into pairing mode. Interactive pairing guide here.
Posted on Aug 28, 2008
EdNelson
  • 149 Answers
SOURCE: My iPhone 4 bluetooth won't
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 04, 2011
Can I connect my garmin nuvi 1310T to my Jabra BT2070 bluetooth headset earpiece
You probably cannot. Some bluetooth devices act like phones, and others act like earpieces. The Garmin acts like an earpiece to offer a hands-free speakerphone while driving. Your Jabra earpiece wants to pair with a phone, not other earpiece-type device.
Apr 18, 2011 | Garmin GPS
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Oct 14, 2010 | Plantronics CS70 Wireless Headset
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
Jul 20, 2010 | Plantronics Explorer 330 Headset
Trying to connect my bluetooth to a new cell phone
turn on your cell; go to settings; find bluetooth settings;turn on bluetooth; find audio device choose search; then turn off the earpiece the light will be red next: turn on the earpiece again the light will flash blue and, the cell will find the earpiece the earpiece will flash blue slowly; once a minute
close the cell; use the earpiece
Sep 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
How do i connect plantronics 330 to my new phone? i have the bluetooth connection on on my phone but it doesn't seem to read it. Its a Sony Ericson W980
Jul 14, 2009 | Plantronics Explorer 330 Headset
Bluetooth connects to LG Vu phone but does not work
I would suggest taking the battery out when the phone is powered on. Replace the battery and try to re-pair the set.
If that doesn't work, then its likely the bluetooth module in your phone is broken. You can validate this by pairing the bluetooth with another handset.
Jun 30, 2009 | LG Shine CU720 Cellular Phone
Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
LG Shine KE970 Bluetooth issues
the pass code is always zeros trust me
Nov 07, 2008 | LG Shine KE970 Cellular Phone
I CAN'T GET IT TO CONNECT
Have you made sure that your phone has bluetooth 2.0? that's the only way a bluetooth headset will work reliably.
Jun 27, 2008 | Plantronics - Bluetooth Headset Plus Base...
Bluetooth & Moto V3m operation
look if the earpiece is compatible with your new phone, usually its a compatibility issue with your equipment.
Oct 21, 2007 | Motorola Mobility RAZR V3
Radio Communications Logo
104 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
