Question about Nike Wr0139001 Triax Fury 100 Regular Watch for Men
How do i get it to count down repeatedly on interval mode
2 Suggested Answers
Can't set the digital time on Diesel DZ721
here are instructions from diesel:
http://store.dieseltimeframes.com/wcsstore/CommonDiesel/instructions/ENGLISH/Diesel_Digital-Guide_ENG.pdf
more specifically
TIME OF DAY MODE
1. Press C to toggle between Time 1 and Time 2.
2. Hold C for two seconds to set Time 1 or 2 as default.
3. Press D to turn on/off key tone.
Time 1
> To set Time, press A until hour flashes. Press B to select the setting
item. Use C and D buttons to adjust the values up or down. Press A to
exit set mode.
Time 2
item. Use C and D buttons to adjust the values up or down. Press A to exit set mode.
> The range difference between Time 1 and Time 2 is 23 hours.
CHRONO MODE
1. Press C to start and stop chronograph.
2. Press D to Split/Reset the chronograph.
3. Press A to recall the memory if Chronograph is stopped.
4. Press A again to view the next lap.
5. Press C or D to exit Recall mode and go back to Chronograph mode.
6. There are a total of 10 lap memories.
TIMER MODE
1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up.
2. Press C to start/stop the timer counting.
3. Press D to reset the counter to the preset value if timer is stopped.
4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute,
second and to back timer-type again.
6. Press C and D to increase/decrease the setting value.
7. Press A to exit the setting mode.
TIMER ALARM
Timer alarm will beep 2 times a second for 30 seconds.
ALARM MODE
1. Press C to select the alarm.
2. Press D to enable/disable the alarm.
3. Press B to change to Time mode again.
ALARM SETTING MODE
1. Press and hold A for 2 seconds to enter the alarm settings mode.
2. Press C and D to increase or decrease the settings value.
3. Press A to exit the settings mode.
Nov 19, 2012 | Watches
Watch Manual for Sergio Valente model# F-IAGAG
These are operating instructions for an SV F-IAGAG (Sergio Valente) watch.
There are four buttons on the watch.
A: upper left
B: lower left
C: upper right
D: lower right
Pressing A turns on the watch face backlight.
Pressing B changes the mode.
From the normal time display mode, one press of B enters the stopwatch mode. In this mode, pressing C will start the stopwatch time count. Pressing C again will stop the count. Each additional press of C will start/stop the count. While the count is proceeding, pressing D will freeze the display of stopwatch time, yet the count will continue. Pressing D again will cause the display to begin updating with the running count. Each press of D will freeze/unfreeze the display update. When the count is stopped (with a press of C), pressing D will reset the count to zero. From this mode, press B again to return to time display mode.
From the normal time display mode, two presses of B enters the alarm time set mode. In this mode, either the hour or minute portion of the time display will be flashing. That which is flashing can be changed by pressing C. Pressing D will switch to the other portion (hours or minutes). Any time the alarm mode is entered and a change is made, the alarm is set to "on". This is indicated by a check mark in the circle display next to the "9" on the watch face. The alarm can be toggled "on" and "off" from the normal time display mode by holding down button D and pressing button C. Return to the normal time display mode by pressing button B while in the alarm time set mode.
From the normal time display mode, three presses of B enters the time set mode. Upon first entering this mode, the seconds display in the circle near the watch face "3" will be flashing. Pressing button C will reset the seconds to zero. Each press of the D button will advance to a different value field for adjustment. The field of adjustment will be flashing. The sequence of fields is (seconds - minutes - hours - date day - date month - date day). Pressing C will change the value. When adjusting the hours, both 24hr format, and 12hr AM/PM format is available. Each press of button C will advance the hour value. The sequence of 24hr format will be indicated with an "H" in the "seconds" circle (near the watch face "3"). After hour value 24 of the 24hr format, the next hour is a "12" value, with an "A" in the seconds circle. Twelve presses of button C will step through the AM hour values and present an "12" value with a "P" in the seconds circle. Twelve more presses advances through the PM hour values and returns to the 24hr format. Pressing button B will return to time display mode.
Pressing button C while holding down button D will toggle the alarm "on/off" state. The "on" state is indicated with a check mark in the display circle next to the "9" on the watch face.
Jan 08, 2012 | Watches
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
Jan 16, 2011 | Watches
What is the 'CD mode' on the Eddie Bauer Travelinlg World Time Clock? What does it do? How does one set it?
The cd mode is a count down timer. Set it like you would an alarm then press the mode button when finished. Then press the up button to start the timer and then the mode or snooze button to silence.
Dec 27, 2010 | Watches
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Nike Wr0139001 Triax Fury 100 Regular Watch for Men Logo
23 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Nike Watch Expert? Answer questions, earn points and help others
