Question about Plumb Pak Plumbing
Plumb Pak lift chain kit PP830-46L instalation
Toilet flapper doesn't stay up unless handle is held down until tank empties.
If the flapper won't stay up, you may be lifting it too high - you want to retain a little air inside it when it's lifted. Try adjusting it to a lower lift height.
Jan 12, 2014 | Plumb Pak Plumbing
How can I remove the locknut and washer to install a handle?
A pump pliers is the best way but remember that the thread is left hand turning... opposite of normal...
heatman101
Sep 03, 2010 | Plumb Pak Home
Overflow outside bathroom dripping how do Ifix it?
Just make sure that the over flow is tight with gasket in place. And all fitting's tight behind wall goin gto tub overflow. If it is check out out next step
1-This is a common issue that comes up. Make sure that the shower valve plate is sealed and tight to tub wall. Reason why I ask that is when you take a shower water will find a way out, down the plate or if tile at the point of where it meet's tub. And will look totally like it's the overflow every time.
May 23, 2010 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Toilet tank to bolt repair has make the leak worse
Rubber goes on the inside. Might be an optional laarge flat washer and nut on the bottom (outside)
Feb 21, 2010 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Could u please tell me how to install a tour pack
Well if you do not already have it you need to purchase two (2) items, the first being the installation kit, and the second the mount kit. Yeah it seems strange you buy the mounting kit and you still need to spend another $70 or so for another kit.
with the kits and or the tour-pak you will have directions and hardware to drill the tour-pak and the bolts to install it with. hope this helps,
JP
Dec 13, 2009 | 2005 Harley Davidson FLHTCUI Electra Glide...
What size gas pipe for 2,000,000 btus low pressure and is there a chart or graph
If you aren't a licensed gas fitter don't touch it!!
What are you fixing that is 2,000,000 btus??
Your furnace is lower than that. Scary.
If you are a licensed gas fitter than you should know this stuff better than those you are asking.
Are you sure it's not 20,000?
If it's 20,000 then write us back and let us know.
Sep 18, 2009 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Installing a new waste outlet hose
You will have to remove the outer shell to access the pump.
Remove the clamp from the outlet side.
Install is the reverse.
Thanks
May 15, 2009 | Plumb Pak Continuous Waste Center Outlet,...
Plumb Pak Corporation Twist & Lock sink drain will not drain
The small disk right under the strainer is adjustable and has a lock nut. You will need to try and adjust this. If it doesn't work, the I would sugest replaceing them. They aren't that expensive plus they are easy to replace. Good luck!
Apr 09, 2009 | Plumbing
Sherwood industrial dishwasher parts I need a waste pipe
The part you need is a common part sold at most all hardware stores, lowes, home depot, or plumbing supply stores.
Mar 11, 2009 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Plumbing Logo
510 people viewed this question
Top Plumb Pak Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumb Pak Plumbing Expert? Answer questions, earn points and help others
