New battery, cables and alternator
Hey Tom , Yes your vehicle has several Control modules on it , but They power down an go into sleep mode after 30 or 40 minuets ,till you unlock a door or use your key fob ! The most draw on the system should be no more then 50 to 80 milliamps Using Voltage Drop To Find Key off Battery Drains
Vary low should never make no start conduition.
Sounds like you have a muility meter to ask for voltages .
Try this disconnect the negitive from the battery .Set the meter on the 20 volt DC scale .Go red lead to posivite and black to engine block or any known solid ground .If you read voltage something is shorting
If the voltage 2 -3 volts it could be switches lights ect .If its 5 volts or over then its something that draws a lot of power like a bad motor .
At any rate if you read voltage pos to gr with gr disconnect from bat their is a short .
You can try pulling fuses 1 at a time to see when it stops .This will tell you what circuit the problem is on and sometimes the starting motor will short interinaly this will kill the bat fast
