Question about GE Televison & Video
Purchased a Genie button remote Model G3t-R on model Ge
How do I program Genie Model H6000-07 purchased Gene 3 Button Remote model G3t-R part 37330R
5 Suggested Answers
AvioriX
  • 689 Answers
SOURCE: ge universal remote
Hi Aaron
I guess you got wrong instructions. You may try with correct instructions.
You can obtain the User's Manual with code list from the link below
http://www.expressfix.net/manuals/remotes/GE-JASRM24912
Posted on Sep 06, 2008
  • 814 Answers
SOURCE: cannot program new phillips remote to rca tv
[http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1] follow this web link it will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using FixYa and have a nice day!
Posted on Jun 19, 2009
  • 3 Answers
SOURCE: I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Posted on Feb 07, 2012
ercupa190
  • 12223 Answers
SOURCE: genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
Posted on May 10, 2012
What is the battery size for a genie garage door remote opener model gict390
The GICT390-1 (one button remote) and the GICT390-3 (three button remote) both use a 2032 coin cell battery.
The manual for the GICT390-3 is available from Genie on their Programming Accessories page: http://www.geniecompany.com/garage-door-openers/programming_accessories.aspx . The direct link to the instructions is: http://www.geniecompany.com/data/products/accessories/manuals/legacy/36484U_1-Btn%20IC1,%20390_3577435796.pdf .
I hope this helps.
Feb 25, 2015 | Televison & Video
If my battery went dead on my remote for my gagage door opener do I have to reprogram remote when I put in new battery?
WIth car remotes they do not need re-coding if the battery is replaced within a few minutes of the old one being taken out.
source: car remote battery sales assistant.
Dec 24, 2014 | Genie gict390-1bl new g3t-bx garage door...
I cannot program my receiver Genie ACSR3 to work with a remote Genie GITR-3
check age difference, every so often the codes change and older parts will not work with newer parts
Nov 03, 2014 | Building Materials
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
Genie garage door keychain remote not working
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 11, 2013 | Genie G3T-BX Keychain Intellicode Garage...
G3T-BX
check manual for erasing codes and reprgraming remotes should be something about a learn button
Oct 21, 2012 | Genie G3T-BX Keychain Intellicode Garage...
Genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
God bless you
May 09, 2012 | Genie Company IntelliCode GICT390-1BL...
How can I connect 3-button remote to my genie intellicode model IS550/A?
The button closest to the Genie logo is the one that works, I just programmed it by pressing & holding the black button underneath the light cover until the red light above the button goes solid then blinks then stops blinking. Next I pressed the same button once and the red light blinks then pressed the button on the remote once then once more and it was all set.
Apr 19, 2012 | Genie Company Genie Series III 3 Button...
Feb 07, 2012 | Home Security
How to set acsctg type 2
There is a button on the motor head you can press. Press it then press the button on the remote 3 times and try it. If not try it again. Genies are bad for not coding in the first time. Make sure there are new batteries in it. Thanks BB
Jul 19, 2010 | Genie Company IntelliCode GICT390-1BL...
Televison & Video Logo
37 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
