Question about CFC Wireless Android Apps
What is happen Samsung triangle ac 3 lights all are blinking on the indoot display
2 Suggested Answers
SOURCE: SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Posted on Oct 26, 2009
When using ac power the notebook does nothing and the power light is blinking 3 times then a solid then 3 more times. and then solid again.. can you tell me what the issue is with the notebook.
In which model laptop is this for, however in most cases if there is a blinking light even though if you have it connected to the ac adpater and this happen, it could be that your ac adapter is bad and is not charging your laptop. Does this issue occue when the adapter is unplugged and running on battery only, or both?
Apr 17, 2011 | Computers & Internet
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
Jan 14, 2010 | Samsung - Projection TV replacement lamp...
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Sep 02, 2009 | Samsung Heating & Cooling
Hello i got a AMANA 9,000 BTU and the light its blinking of the triangle and i lost the manual of the AC can you tell me what can i do i cant turn on my ac
I have the Maytag version of this machine and the blinking triangle light means the water tray is full. The machine won't operate until that water has been drained -it's the little black tube with the plug at the bottom behind the machine. Pull the plug, tip it down (preferably with a shallow pan underneath to catch the water) and drain as much as you can. Once you've done this, put the plug back in and it should start.
Jan 24, 2009 | Amana Haier AP095R Air Conditioner
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Printerndoes not respond
I thought my printer died on me, but it turned out it was a simple paper jam. The whole printer just locked up because of a paper jam! All I had to do was open the top compartment, remove the toner and get rid of the paper jam
Jul 25, 2008 | HP LaserJet 1320n Printer
Toshiba Satellite A55-s1066 wont boot
Check out this Toshiba document - http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=571487xml&sliceId=&dialogID=19454183&stateId=0%200%2019450573 Look about half way down the document to the section that starts with: * If the AC power light is blinking, try the following steps:... See if any of those suggestions help.
Sep 17, 2007 | Toshiba Satellite A55-S1066 Notebook
Android Apps Logo
512 people viewed this question
Top CFC Wireless Apps Experts
Are you a CFC Wireless App Expert? Answer questions, earn points and help others
