Question about Acer Computers & Internet
How do i use hp1740 with my acer laptop - Acer Computers & Internet
  • NOEL
    NOEL Apr 19, 2015
    Hi chino rivas, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Need factory settings aspire 5920
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operating, registry problems, virus problems, spyware issues and more. And a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
1.Back up all necessary data to an external device such as a disk, flash drive or hard drive
2.Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
3.Detach any external hardware such as an external hard drive or printer.
4.Press the Power button to boot your Acer laptop.
5.Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
6.Select "Restore System from factory default" in the Acer eRecovery Management window.
7.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
8.Click "OK" in the notice window to proceed with resetting your Acer laptop.
9.Wait while your Acer laptop is reset to factory settings.
Sep 06, 2011 | Acer Aspire 5920-6727 Notebook
How do i reset my whole acer aspire 3690
unplug power and battery. This is a hard reset
Nov 30, 2010 | Acer Aspire One PC Notebook
My acer laptop needs restoing
To restore to factory setting, power up the laptop, when you see the logo, press both Alt and F10 key, it will initiate the recovery program. Follow the instruction on screen to restore to factory setting.
CompQ
May 11, 2010 | Acer Aspire One PC Notebook
How do I reset my Acer Aspire 5517 to the factory settings?
click start menu, click all programs, look for Acer and click on it. Then click Acer E recovery. in a few seconds a window will come up. click the restore option in the left hand menu. You can restore to factory condition or restore windows and save your data. its all pretty much there in front of u. hope it helps u
Apr 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
HP1740 does not react anymore on switching on. Is there a way to open the monitor to check connections? Is there a fuse that could be dead?
It will more likely to be bad caps with bulging top in the power supply section, that is the first place to look, just open the case up using thin flat blade screw driver starting at the bottom edgs of the case, just make sure to remove all the screws and the base first. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Mar 04, 2010 | Computers & Internet
How do I get the built-in speakers to work
Are you absolutly sure that it has speakers? If you're absolutly sure it does, there should be a 3.5mm audio in jack on the back or bottom of the monitor. It will look somewhat like a headphone jack, just like the ones you see on ipods (same size), although it may be green. You need a cable with a 3.5mm jack on either end.
Dec 02, 2008 | HP L1740 LCD Monitor
Acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
Oct 19, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
