Question about Bosch Vacuums
No power, fuse has been checked. - Bosch Vacuums
    Top Expert:
  • Bosch Master
  • 51,484 Answers
Possibly bad switch or cord wire pulled loose inside
Posted on Apr 16, 2015
Stopped working during use. Cooled down, been two days, still no power at all. Could it be a fuse? If so, how do you change it? Thanks!
Might be a fuse but probably not. Could be an internal thermal breaker or thermal fuse but internal breaks in the power cord are common faults with portable appliances.
If you are competent and can work safely it needs systematically checking through with a multimeter.
Apr 24, 2016 | Dyson Stowaway DC23 Bagless Canister...
Where is located the fuse in a vacuum claner Kirby ultimate G?
There's no internal fuse, it is in the plug (UK version anyway). Not sure on US version.
If the unit is dead it could be several things. Bag and brush roller not fitted correctly you can check this yourself, motor brushes worn out, broken power cord etc.
Jul 24, 2014 | Kirby Ultimate G Bagged Upright Vacuum
Dead Dirt Devil Featherlite
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Nov 03, 2012 | Dirt Devil Featherlite Bagless Vacuum...
No spark,no power to ignition module
Do you have power to the fuse? Sometimes fuses look good, but are actually bad. Check with volt-ohm meter. otherwise bad connections and or wire, corrosion causes a lot of bad behaviors, clean to bright metal for all connections and contacts. Again check with volt-ohm meter, or "indicator" light method.
Nov 03, 2012 | Clymer Harley-Davidson Dyna FXD Evolution...
The microwave will not turn on. No power. Checked fuse box and power outlet...not the problem. Unit just wont turn on? Is there a reset button or another option.?
Remove the cover and locate the internal fuse you will find near the power cord entry. Replace with the same.
Sep 04, 2011 | Vacuums
Shredder does not power on
Good day!!!!
please try to check the plug if it is OK..
Then look for the fuse if busted...
If the fuse is busted look at the fuse if only disconnect the wire inside so that you can determine the cause of blowing of fuse..if the fuse is dark or have color black inside your machine have a short circuit..if not got fluctuate high current in split second (that is normal)..just replaced the fuse with the same type and ratings..
If the fuse always blows after power ON your machine need further repair it have short circuit..
Thanks for using fixya...
Aug 10, 2011 | Vacuums
Does the trivac 1100 have a fuse? My machine has suddenly stopped.I have checked the fuses in the plugs and also made sure that power is at the wall socket. I can see what loks like a fuse holder in the...
an attached photo would be better to explain this
I don't feel its the fuse
normally the fuse is inside the vacuum.
the problem you facing could be your power cable broken somewhere inside, if not this then something inside the vacuum
could be the motor itself
Oct 23, 2017 | Philips Vacuums
Jm3 hoover just cut out a few days ago,its not the fuse,can anyone help ,thanks
If the fuse is good. You may want to take a test light or voltmeter and check your power switch to see if it is good. If it is good, then you will want to do the same with the power supply and mabe the power cord as well
Sep 28, 2009 | Vacuums
No power coming into machine
Hi All
Up Date on shark no steam no light.
The fuse that controls the steam is a thermal fuse, 192c ,10 am 250 volt.
Now that may sound strange to some one who dose not know fuses, but Radio Shack carries them and there $3 bucks!
If there is a handy person you know, they should have no problem replacing the fuse. I just fixed ours in about 30 min. but I work on electronics. If the Shark gets to hot this fuse will blow to prevent overload or fire so don't put bigger fuse in it!!
FYI you have to take All the screw out and open up the unit fuse is burried look for yellow clear film (thats the color mine was), the film is wrapping the fuse. Good luck
May 09, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Power head
If you have checked the power delivery down to the powerhead and you have current running to the powerhead, then you likely have a burned fuse. There is a fuse built into the powerhead motor and is usually located on the field winding. This is not easy for a novice to replace and even most professional repair shops will replace the motor. It is possible to replace the fuse if you know what you're doing, but if the fuse blew, there may be a more serious problem, after all, the fuse is there if the motor starts to experience distress and the fuse will blow to avoid any electrical issues. The fuse can blow if something is jammed into the roller and causes the motor to labor heavily. If this is the case, then the fuse can be replaced safely. If the motor is burning out, then a new fuse will just blow immediately after replacement. What I do is take the fuse out and run the motor without it to see if the motor is still viable and replace the fuse if the motor proves to be o.k.
Feb 08, 2008 | Eureka 6831A Bagged Canister Vacuum
Vacuums Logo
81 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
