Question about Kenmore Kitchen Ranges
Periodically, front burner jets on my Kenmore Model 790,7250 become weak and just as unexpectedly resume at full blast. Why? How can the problem be solved?
Here are the model numbers on the Use/Care Guide that came with the stove; not sure which one my stove is: 790.7250, 7280, 7290.
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 646 Answers
You might have a sticking gas pressure regulator.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Posted on May 27, 2015
  • 409 Answers
SOURCE: Kenmore electric stove model c880.6383880
hi,
sounds like you have the old-style coil elements on you stove.
your problem is the switch under the element, called the infinite switch. i would suggest to have a technician replace it. they usually charge for the labour but if you have never done it before, it's money well spent.
Posted on Sep 13, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore range model number 790.9568330. Stove
Check your electrical receptacle, breaker, and power cord.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 15, 2010
sonicboomele
  • 1557 Answers
SOURCE: GE Profile Model #J2B915SEH2SS Weak Flames
you need to get your gas company in and make sure your supply is going into your home at the right presssure
Posted on Apr 20, 2010
SOURCE: New Kenmore range model number 790.7230 - front
Replace Dual Heating unit In glass top kenmore 790 electric Range.
Posted on May 29, 2011
What is the boost on my sa.d filter for ?
Most booster pumps are hooked up to the floor jets that periodically blast water in different directions to move dirt around so it can be sucked into the filter. They are never hooked up to a filter, only one pump per filter.
Aug 11, 2015 | Pool & Spa
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
Front right hand burner turns itself up to high has caused damage
it may just be as simple as changing the valve the knob is connected to. These parts use a few springs sometimes that may be too strong and/or too weak to hold it where you put it and can be replaced simply by removing it and replacing with a new one. (usually just a screw or 2 and a couple hoses)
Apr 07, 2014 | Kitchen Ranges
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Kitchen Ranges
I have kenmore gas oven ignitor glows but will not light
Hello there:
It doesn't bake dot_lineone.gif Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
Feb 01, 2011 | Kenmore 33169 Gas Single Oven
Weak Flames on Propane Grill
It is possible that your burners are clogged. Clean the burner ports with a paperclip (not a toothpick).
Jun 01, 2009 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Dryer works but no heat
Many times when the gas solenoids get weak the gas will light for a very short time and not light again. One coil has 3 connections and is used to make the ig-niter glow hot and turn the gas valve on too. If it becomes weak over time it just does not have the strength to hold the gas valve open. Go to my page below and enter the model number listed inside the door frame. If you cannot find the part here go to sears parts and see if you can locate a kit of 2 solenoids. My site also offers free help.(click on link below)
http://servicepartstec.blogspot.com/
If you need help with anything just let me know,
Thanks, Sea Breeze
Mar 23, 2009 | Kenmore 73952 Gas Dryer
Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
Dec 17, 2008 | Kenmore 16322
Amana oven won't turn on gas flame
Sounds like the oven ignitor has become too weak and needs replaced. When power is applied to an ignitor it builds up resistance in order for the gas valve to open and let gas flow to the burner. When they become weak this will not happen. If you notice a whiteish color on the ignitor or it doesn't have a strong full glow that is a sign of it going bad.
Nov 11, 2007 | Kitchen Ranges
Kitchen Ranges Logo
108 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
