Kobalt 1 HP 2-Gallon 135 PSI Electric Air Compressor U12HCCL Logo
Ron Collins Posted on Apr 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change belt - Kobalt 1 HP 2-Gallon 135 PSI Electric Air Compressor U12HCCL
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on May 16, 2015
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
500464
Points
3432
Is the transit connect 04 plate cam belt or cam chain can anyone tell me please
My information is it has a belt driven camshaft, it is after all a development of the old escort diesel though the replacement intervals are somewhat extended with 100,000 miles or 120 months, whichever occurs first, being the recommended interval though the Haynes manuals persist in suggesting timing belts are changed at 40,000 miles.
I certainly suggest doing a visual check whenever routine maintenance makes it convenient to do so and then change the belt should it appear dusty, frayed or oily. If there are no recorded belt changes I always change a belt when the information printed on the belt is no longer visible or is so faded it can hardly be read.
The first belt change can perhaps be left to the recommended interval with a minimum but rapidly increasing risk I feel subsequent belt change intervals should be increasingly reduced.
3answers
1996 Mazda Protege with 100,000 miles. Should the serpitine belt be changed? What is approximate cost?
Drive belts are replaced every 5 years
Your thinking of timing belts 80,000 miles
I bought used Optima 2004 with mileage around 120k, i'm worried about the timing belt. Should I change it now? When should we make second or third change after the 60k timing belt change.
to be on the safe side id change the belt every 55,000 to 65;000 miles make sure u change the belt tensioner as well they fail more than the belt
3answers
What is Ford's recomendation (mileage) for replacing the serpentine belt on a 1998 Ford Explorer?
Theres no mileage to change just to check it, the way to check the belt is to look at the inside of the belt and you will see grooves in which the belt rides, if you see cracks in the belt then its time tom replace. the belt should be looked at every oil change it thats no time to check. hope this is helpful.
2helpful
2answers
I have 151,000 miles on my 2002 4cyl Camry and have not changed the timeing or the sepeitine belt: Is it time to have it done?
Hi:
It is overdue time to change your timing belt and waterpump, as you are on borrowed time on the timing belt. The waterpump and tensioner should be changed along with the timing belt, as they can ruin a new timing belt if they fail. Your serpentine belt should be inspected and replaced if needed too.
2helpful
Peugeot Expert Van Cambelt change
Most cam belts need to be changed every 60,000 miles. I would change again somewhere around 126,000.
17helpful
2answers
When to change timing belt on 2004 honda civic
Honda reccomends timing belt change at 100k. Most Honda dealers like you to change the belt at 90,000 miles (90k). some auto repair places will want to change the belt at 60k but that is not necessary (Note: if in a severe cold or hot climate like florida or canada you would change the belt before 90k or if the belt is over 7 years old.. Good luck:
I’m happy to help further over the phone at https://www.6ya.com/expert/gregory_8e6ba270263743ac
1helpful
2answers
Timing belt
Timing belts are suppose to be changed every 60,000 miles.
Top Kobalt Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Kobalt Air Tool and Compressor Expert? Answer questions, earn points and help others
