Washing Machines Logo
J
Joseph Posted on Apr 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
About a minute or into doing a load the red "door locked" light begins to flash and it won't wash.
I can open the door immediately, but it's locked in and watertight. Drain cycles work with no issue. Sometimes after it's been left off for a while normal wash cycles work as well, but lately haven't. I have not called a repair person yet. It's a Whirlpool Front Loader AWO 3561, it's about six/seven years old.
tom cassidy
Level 3:
Genius:
  • Washing Mach... Master 1,585 Answers
  • Posted on Apr 16, 2015
tom cassidy
Level 3:
Genius:
Answers
1585
Questions
Helped
322605
Points
3520
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Whirlpool wfc7500vw when put into any cycle selection the door lock lights comes and stays on and the draining/unlock light flashes for a minute then the door unlocks once opened and closed the cycle...
When you first start a load, the machine does perform several self checks. One of them is the door lock test. It locks the door and checks a loop back signal from the lock. At this point, it usually tests the drain pump to make sure it cycles on and off. In my case, the Maytag unit we own actually unlocks the door and immediately locks it again right before the actual wash cycle begins. I suppose this is a double check because if the door indicates it is unlocked, the washer won't do anything (like fill up with water, or spin...anything that either floods the room and hurts somebody). The door switch should be the impetus to start the tests. If the switch is mounted to an adjustable bracket, or the bracket is loose, then maybe it is being pushed out of position when you close the door. The fact that you can open the door after it unlocks, re-close it and the machine works normally tells me there is adjustment that needs to be made. Either the the little lever or pin that actuates the switch is bent or broken, or the door needs to be adjusted on its hinges to get the pin aligned correctly. Hope this helps. Keep us posted.
Kindest regards, Carl
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Washer won't start, stopped at beginning of cycle and the door lock flashed. after about 5-6 flashes the display read: FL. Tryed to start again, unplugged it for a while several times. nothing happens....
FL:
Failed to lock.
Trigger:
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Action to be taken:
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
If you need to open the door.
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
1) Remove the bezel from the soap/bleach/fabric softener dispenser.
neptopbezel.jpg 2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Best of luck, Any questions just ask
1helpful
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
1helpful
Washing machine not working
I Put A Set Of New Brushes In motor And It started
Top Washing Machines Experts
john h
