Takes 30+ minutes longer than shows at beginning of wash cycle
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check heater element or sensor
Posted on Apr 16, 2015
  • 1462 Answers
SOURCE: wash cycles far too long!
you may have the hot and cold hoses connected wrong way round. water flow from hot is often very slow hence the extended times. to check, put on rinse which should let cold water in. see if it is in fact hot water coming in and this confirms hoses wrong way round. just interchange them. smell could be due to using liquid detergent. change to powder type
Posted on Jul 09, 2007
  • 4 Answers
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Posted on Sep 02, 2008
BNewberry
  • 93 Answers
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Posted on Jan 12, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Wash cycle taking way too long, like 90+ minutes
You timer is bad and needs to be replaced. Your problem is a common error and is something a lot of people on here run into. You can go to repairclinic.com and get this looked at
Posted on May 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: 2008 Samsung front end loader develops a 4E error
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Posted on Sep 16, 2010
How long is the wash cycle?
seems abnormally long as most full wash cycles ore only 60 minutes unless you include a soak section in the wash which will take longer
check for a deep rinse also adds time
Jan 31, 2016 | Kenmore Washing Machines
Wash cycle takes too long
If the incoming water is very cold it takes longer to heat
this extends the cycle length
Sep 20, 2014 | Bosch Washing Machines
Manua beko 5kg aa class 1000 rpm
most washers on a full wash cycle take about 60 minutes. It will take longer if you use a soak cycle with extra minutes because if you have a soak cycle and you set it for 30 minutes the total wash time will be around 1 hour and 30 minutes.
Jun 22, 2013 | Washing Machines
I have a couple of problems. Firstly, the auto programme now shows a cycle time of 199mins but actually takes much longer than that to complete - more like 4 hours. On the quick (!) wash cycle the time is...
There is an issue with the machine not heating properly, it could be the control panel or the thermostat, The flap not staying shut is not connected to this.
Mar 12, 2012 | Dishwashers
Cycle takes 3 hours instead of 30 minutes
You timer is bad and needs to be replaced. It is located behind the control board
Apr 20, 2009 | Washing Machines
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Shutting down on rinse cycle
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Gateway 831 GM won't boot up no signal is showing in the begining
ram,
It sounds like the problem is either your power supply OR the motherboard. A power supply swap doesn't take long or cost much.
On the other hand, replacing a motherboard takes 30 minutes or longer and can cost upwards of $100!
Please let me know if this helps. Good luck!
Mar 01, 2008 | Computers & Internet
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
