Question about Refrigerators
Can I easily change the door from a left swing to a right swing? do I need to buy new hardware?
  • robert Apr 16, 2015
    Either give make and model or post a photo
  • Amy Haass
    Amy Haass Apr 16, 2015
    SAMSUNG Model# RB1955VQ
  • Refrigerators Master
  • 932 Answers
Amy,
You should be able to reverse the door without much problem. You should not have to purchase any hardware. One way you can tell if you can reverse the doors is to look on the opposite side and see if there are some plastic buttons that cover up the holes where you would switch them. Hope this helps!
Posted on Apr 16, 2015
How do I switch the door opening to the other side? I would like to change the dryer door opening from the left side to the right side. By looking at the dryer it appears this is possible.
Hello, Frazer -
Without knowing the make and model of you clothes dryer, it is a challenge to provide you with the precise directions for changing the swing of your dryer door. With that being said, this YouTube video may prove helpful to you: https://www.youtube.com/watch?v=VW9183PsCLc .
How did I find the YouTube video? Using Google I entered the following search statement, with quotation marks, as indicated: "clothes dryer door swing" .
This web page with written directions may also prove helpful:
http://homeguides.sfgate.com/change-dryer-door-left-right-66754.html .
Best wishes.
Dec 17, 2017 | Dryers
Do i have to purchase new door hinges to change the swing of the doors or will exiting hinges work to make the change???
never saw duel swing hinges . righties swing right lefties swing left , so I would say YES you need to buy the other ones
Jul 27, 2015 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Change door swing
Ok before you can do this you need to work out weather or not the fridge has provisions for it.
first have a look on the top of the fridge and see if there are screw holes with plugs in them.
if they do then check under the bottom skirt and see if they are there as we'll.
if there is then you are in luck and you can do it very easily .
make sure that all your goods are off the door first.
release the bolts on the top and bottom and change the brackets around to where they need to be .
with some fridges, you swap them around top to bottom, I'm not sure with this one but you will find out soon enough
you will need a small socket set, screw drivers ,a level and about two hours.
Jan 15, 2014 | Viking Professional Series VCBB36 Bottom...
Reverse door swing
Hi halej308 - Unfortunately Frigidaire front load washer doors cannot be reverse.
Sep 29, 2012 | Frigidaire Affinity ATF7000E Front Load...
I always get confused as to the door swing direction and I need to replace one of the handle sets. Before I order I need know if it is a right or left hand door. Can you help?
Yes, Here's how. It's all about the hinges. Facing the door from the outside, if the hinges are on the left, and the door swings to the inside, it is a left hand opening door. If it swings in with the hinges on the right, it would be a right hand opening door.
Best regards, --W/D--
Jan 28, 2011 | Garden
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
How do you change the way the door swings for hoover HE370TC
if you have plugs on both sides you can change the door swing . not all doors will change l & r / hardware on left returns to other side and so on .. but look for the screw hole's before removing doors. mm
Dec 03, 2009 | Dryers
I need a new remote for my window ac
You will probably have to contact the manufacturer to get a replacement. Sometimes you can get lucky on ebay. These items aren't typically found easily if you don't go through them.
Jan 19, 2009 | Hitachi RAS-09UH Air Conditioner
How to reverse door on kelvinator fridge?
Im unable to look up htat particular model number for you, looks like my FRT18, which is made by the electrolux company, in which case, YES you can easily switch the door swing form one side to the ohter, whats on the left goes to teh righ and right to the left, not a problem
Jan 11, 2009 | Refrigerators
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
