Question about Zedge Ringtones Wallpapers
Tonesync keeps saying to verify itunes is installed. it is installed. i am using windows 8. how can i fix this
Ipad disabled how do I connect it
Use the charger cord to connect the iPad to a computer with iTunes on it.
Dec 04, 2014 | Apple iPod touch
Asus 53 n laptop
1. option - Removing Windows 8 by installing Windows 7 over it*:
Go to the disc where you have the Windows 7 installer.
Then right click, click on Mount, when done, click on the Setup file and install Windows 7 over your current system.
2. option - Keeping Windows 8 and installing Windows 7 alongside it**:
Restart the Windows 8 system, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 .iso file on.
3. option - Running it from a DVD, but keeping/removing*** Windows 8:
a) go to the disc where you have the Windows 7 .iso file installer.
b) move the .iso file to a easily accessible place like Desktop.
c) then right click on the .iso file and click on Burn disk image, choose the DVD you want to boot from ( You need a readable DVD), and then check the checkbox which says " Verify disc after burning ".
d) click on Burn.
e) when that is done, close all open programs or/and windows and restart your computer, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 installer on.
Note - please read everything carefully. I suggest you to use the 3. method.
* - when in the setup, you have no option to go back to Windows 8.
** - this step might not work, because not all computers support that.
*** - you can choose to either create a new partition on which you will install Windows 7 or install it over Windows 8 by either kepping or not keeping your personal files.
Please reply to this solution: did it help you or not and what improvements in my solutions do you want, and rate my solution from 0-5.
Jan 12, 2013 | Computers & Internet
I am trying to download iTunes onto my computer, but when I get to the end of the process where iTunes and QuickTime are to be installed it wont. A small box pops up saying "iTunes could not be...
Hi there!
There can be several reasons why you are getting this error message. First, make sure that your user account is an administrator account. If you are sure that your account is an admin, follow this steps:
1. Choose Run from the Start menu. type %Temp% and click OK. delete all files inside the temp directory 3. Click again on run from start menu. Type cmd and hit Enter. 3. Drag iTunesSetup.exe from the Desktop into the C:\\WINDOWS\system32\cmd.exe window. 4. Add a space and then this text: /extract %TEMP% 5. Press return/enter. This will extract three Windows installer packages into your TEMP directory. 6. Navigate back to your TEMP directory. 7. Launch the AppleSoftwareUpdate Windows Installer Package. Complete the installation. 8. Launch the QuickTime Windows Installer Package. Complete the installation. 9. Launch the iTunes Windows Installer Package. Complete the installation.
Please reply if this will not fix the problem. Cheers!
Apr 23, 2011 | Apple iTunes
When trying to download itunes keep getting a report that says ''windows installer encountered errors and can not configure itunes.'' I am using a 64 bit PC with Windows Vista Home Premium. Thanks.
It means that the installer you downloaded is not compatible with the version of Windows you're trying to install it to. Make sure to visit iTunes.com and select the right installer for it to work.
Feb 19, 2011 | Apple iTunes
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
Itunes drivers for importing and burning CDs/DVDs missing where can i get them? Bill
It seems that some users installing iTunes 8 on Windows systems are encountering an error message:
“ERROR: The registry settings used by the iTunes drivers for importing and burning cds and dvds are missing… Please re-install iTunes”
iTunes uses GEAR software drivers for importing and burning CD’s & DVD’s. Re-installing (or installing the latest GEAR drivers seems to fix this problem. No reboot required for this install.
You can get the current GEAR drivers here: http://www.gearsoftware.com/support/drivers.cfm
If this does not fix your problem download a fresh installer for iTunes here: http://www.apple.com/itunes/download/
Uninstall iTunes, reboot, & then do a fresh install of iTunes.
Hope This Help You
Oct 26, 2009 | Apple iTunes
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
Oct 22, 2009 | Apple iTunes
Window itunes.exe-unable to locate component. box
hey, dll is a file in your pc, try to look for a qtcf.dll in the internet then try to download it,else try to re install your itunes, but use other installer, maybe the installer is corrupted.
Sep 30, 2009 | Audio Players & Recorders
Ipod says use iTunes to restore
That means you have to reinstall Itunes:
Here you find the downloads:
iTunes 8 for Macintosh
iTunes 8 for Windows
Sep 25, 2008 | Apple iPod nano
Zedge Ringtones Wallpapers Logo
440 people viewed this question
Top Zedge Apps Experts
Are you a Zedge App Expert? Answer questions, earn points and help others
