Question about Panasonic Tc-p50x3 50-inch Viera 720p Plasma Hdtv
I had my 50 inch panasonic veira flat screen tv on when it was thundering in lighting in now i have no hd
  • Panasonic Master
  • 680 Answers
Hi Carlos,
Thundering and lightening can damage your set in many ways. Sometimes if you are lucky, you escape with a blown fuse and some minor safety components damaged. Well open the back cover and see if the fuse is blown. If there is no other visible damage, try a new fuse of the same rating. If the tv works, well and good and if the fuse blows again, please consult the TV tech.
Good luck.
Posted on Apr 16, 2015
james klgr
  • 362 Answers
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Posted on Dec 24, 2007
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
jerryg50
  • 1667 Answers
SOURCE: panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
Posted on Apr 14, 2008
RixsFixes
  • 2200 Answers
SOURCE: panasonic hd tv light blinks 7 times
Unfortunately this appears to be a common issue developing with these Panasonic sets i.e the '7 blinks of death'!
Several customers are complaining about it. The problem is caused by one, both, or all of the following boards: SC board, SD board, and SU board.
Most commonly, the SC board is the one that has failed and because Panasonic have received so many complaints about this issue they are now agreeing to replace the SC board under extended warranty.
However this is not widely known amongst the general public and Panasonic have kept it very quiet.
I would suggest that you make contact with the Panasonic Concierge service centre. Make them aware that you are aware of the SC board issue and that there is an extended warranty on this and ask them to replace it.
However if it happens that one of the other boards has failed be aware that Panasonic are not covering these under warranty and you will be charged for the repair in this case.
The Panasonic Concierge service is available from here
Thanks for using FixYa.
Posted on Jul 09, 2010
SOURCE: i have a panasonic 50 inch tc-50px24 plasma tv. i
blinkin de red led tv panasonic plasma
Posted on Feb 13, 2011
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
My panasonic plasma TV screen will light up, but no picture shows.
Have you tried replacing the cable? They can cause all sorts of trouble.
Oct 19, 2015 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
Horizontal lines across the lcd panel, how to fix it?
Couldn't find your model number on the Panasonic Website, however, I did locate that they have 2, 32-inch models. Try this link: http://shop.panasonic.com/shop/model/TC-L32XM6?t=tutorials&support#tabs
I would suggest clicking on the Help and Tutorials tab and follow the instructions for "How to Reset your Panasonic Veira TV". If that fails, try researching their site more or contacting their Support team for help.
Dec 23, 2013 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic tv has a cracked screen
you probably better off buying a new tv cuz the amount you will pay will equal the amount of a new tv and plus that screen has like a million LED lights that the costly part but thats not why but the most costly part in the tv is the screen.
Mar 28, 2013 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Making my HD tv look the best it can
If you have the halo 3 bonus disk use the THX optimiser on it, if not then the setting I use are:
Viewing Mode: Dynamic
Contrast: 60
Brightness: 50
Colour: 50
Sharpness: 50
Tint: Middle (need the lenses to set it properly)
Colour balance: Cool
Colour Management: On
P-NR: Off
I got both setup through HDMI atm.
Jan 06, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic Viera 37 inch Plasma won't read DVD player
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
Mar 16, 2008 | Televison & Video
Panasonic Tc-p50x3 50-inch Viera 720p Plasma Hdtv Logo
102 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
