Question about Garden
What engine oil do I use in my sit on mower - Garden
    Problem Solver:
  • 7 Answers
Nah 2 strokes for mixed fuel use a 5w30 unless its like a toro grounds master then you use 90 weight but yea 5w30 is what you want. If you live in a colder climate use 10w30
Posted on Apr 18, 2015
    Champion:
  • 225 Answers
NO NO NO You DO NOT put 2 stroke oil in a ride on mower as i very much doubt its a 2 stroke engine. !!!!!
if its a briggs and startton engine you need SAE30 oil,
if its a Honda or Kawasaki then its 10w 30 or 10w 40
Posted on Apr 17, 2015
  • 1,602 Answers
You use what they call 2 stroke motor oil
the same as you use in the motor cycle, chain saw, wed eater,
and so on, if you are not sure go in auto parts store ask if they can look it up for you.
Posted on Apr 16, 2015
Water in oil of John Deere L108. Causes?
If the mower was sitting outside and the ambient temperature is hit during the day and cold at nite, the engine and the the fuel system can be affected by condensation. If you are in a humid climate the effects will be sooner.'usually when you run an engine the heat of the engine will evaporate any moisture, but if it has been sitting for a while you can develop water in the oil. Or someone left it outside with the oil dipstick out or loose in the rain. Hope this helps.
Jun 25, 2016 | John Deere Garden
Will not autostart sitting in shed for 3 years new. autostart turns over but no combustion or limited combustion in engine how do I choke this engine?
If it was sitting for 3 years, I would do a complete tune up. Oil change, air and oil filters, plugs and put in new gas. Good luck!
Mar 15, 2016 | Garden
Mower won't start
Battery charged?,sitting on the seat?, starter or solinoid working? Take out the spark plugs and try turning the engine underneath by using the pulley. Is the oil fresh?
Apr 20, 2014 | Craftsman Garden
My husqvarna 61 inch lawn mower will not stay running
Did you check the oil? Some engines have a low oil shut off switch to prevent the engine from running out of oil and burning themselves up. If it is low in oil and all the oil is up in the engine to lubricate, then the switch may be setting itself off. After a few minutes, the oil comes back down to satisfy the switch and it starts back up, but only till the switch is activated again. Might do it???
Dec 27, 2011 | Husqvarna Garden
How to drain oil from briggs & stratton 5.00 158cc engine
underneath the deck there is a plug, sit mower on bricks/wood and pull plug and use a bucket to catch old oil. Tim
May 22, 2011 | Garden
I need to change the oil - how
warm up the mower for a few minutes. This gets the oil thin and suspends the dirt in the oil.
Then, get a pan big enough to hold about 20 ounces of oil.
remove the oil filler cap and tip the mower towards the side of the filler neck with the pan
sitting on the ground next to the mower to catch the oil.
sit mower on its side for about 15 minutes and let all the oil drip out.
Tip it back up and fill her up! 18 ounces for small mower engines. 30 Weight Non-detergent oil.
May 03, 2011 | Briggs & Stratton Garden
The mower is turning over but won't start.' My husband is away so i have to solve it myself. its a LTH 1797
Hi and welcome to FixYa, I am Kelly.
You must be sitting on the seat to start the unit and.... make sure the engine oil is serviced properly. If the oil level is low the low oil level sensor will ground out the ignition and it will not start. (no spark) If you have a choke... you must use the choke on a cold engine. This is just the basics. If your sure the engine is full of oil and it still will not start have someone help you with a spark test. The spark test is done with the spark plug wire disconnected from the spark plug or the spark plug removed. It is hard to do this test alone as you must be sitting on the seat to get spark. Feel free to ask any questions anytime.
Thanks for choosing FixYa,
Kelly
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Have a toroZ5035 mower 90 turn) with kawasaki engine. **** smoke appears on start up, but goes away when warmed up. choke must be kept on at least halfway or motor dies. changed plugs and cleaned air...
**** smoke sounds bad, If what you meant was white smoke then I know what is going on with the mower. The white smoke is from the extra oil in the cylinder head. There are tow causes for this. #1 the engine rings are worn and will not prevent the oil from running into the combustion chamber as the engine sits. #2 the carburetor is leaking fuel into the oil and thinning it out. This thin oil bypasses the rings easier and drives the oil level up too. I would recommend a carburetor rebuild. You can get parts from a local dealer like www.arcolawn,com Good luck barterjoe_64.png
Mar 23, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
Cannot pull rope out to start mower
Bad news , Mower has sit up too long and the piston / crankshaft has become rusty and froze in place. (fix) buy some liquid wrench it comes in a can at your local hardware store...Tilt the mower onto its front wheels and remove the spark plug. Fill the Cylindar with the oil and leave it for a couple days. after a few days lean the mower back and attempt to pour out the left over oil. Then (Check Your Oil level) preferable replace old oil and pull choke..and start mower...if the engine is still frozen (Buy a New mower) 125bucks Sears.
Mar 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
