Question about Fagor Washing Machines
My fagor washer is showing "00" and a long beep sound when I turn it on. It turns on but will not allow me to start a cycle. It only stays on "00"
  • 1,602 Answers
Go to the following sites
www.ask.com/fagor_shows_00_and_long_beep/
www.infolinks.com/fagor_long_beep_00/
www.wikipedia.org/fagor_long_beep_error_00/
Posted on Apr 16, 2015
  • 8 Answers
SOURCE: Bosch Washer
Yes, check the brushes. Our 7-yr. old WFK-2401 just stopped spinning and a brush change did the trick. Repair people wanted $350 for a whole new motor, but it was only the brushes. Replacing them is not very difficult if you are somewhat handy with a 1/2in. wrench and have some common sense about mechanics and electrics. Just look carefully as you loosen motor - disconnect its wires first, and think, and study, and try to understand what you're doing. I took lots of photos just in case. In the end it was easy; make sure to get belt off motor and motor will be out in no time; just two bolts to undo. Also, make sure you put brushes in properly - their tips are slanted and need to go in the right way and make full contact with commutator inside. Again, common sense. Bosch sells brushes, also RepairClinic.com, for slightly more but real Bosch parts. I paid the latter $45 with shipping - Bosch part No. 154740. Another option is to take motor out and find local motor repair shop and have them do it. Bosch won't help you. Power to the people - and the motor!
Posted on Sep 05, 2007
Krazytech
  • 725 Answers
SOURCE: GE Harmony Washer Beeping
first I would to a hard reset unplug washer and dryer for 30 sec then plug back in... also check the wire that connects the washer and dryer ....if this don't wark let me know I can tell you how to get the error codes out of it... let me know
Posted on Sep 13, 2008
  • 12 Answers
SOURCE: F02
you might try here fill in your model and search for user manual download
http://www.fagor.com/mun/_bin/ingl/downloads2.php
Posted on Mar 28, 2009
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Posted on Apr 19, 2009
SOURCE: my ge profile harmony washer will turn on but will
try taking apart the control panel and unplugging the main and control board. Wait for 15-20 minutes and replug. Repairman said mine had static in the system and unplugging cleared it.
Posted on Aug 05, 2009
My Fagor dishwasher di not finish the cycle and has water in the bottom of the machine which has not drained. Now it will not start and just beeps. How can I drain the water and get it to start and fu
A small amount of water in the bottom is normal (it allows the pump to be pre-primed). Do not remove the water (as long as it is only a little in the center well).
Nov 03, 2014 | Fagor Dishwashers
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
Why does my fagor dishwasher stop mid cycle and show f 6 with several beeps
I have already provided answer to a later post on this topic. Heater problem.
Sep 19, 2014 | Fagor LFA-013 Stainless Steel Built-in...
Atf7000es0
Good Morning John, thank you for allowing me to assist you! Here are some simple troubleshooting steps to help resolve this issue:
  • First, reset the unit by either unplugging it or flipping the household circuit breaker.
  • Wait approximately ten minutes and turn on the power for the washer.
  • Next, turn on your washer and select a normal cycle.
If your washer continues to beep, it could possibly have a defective control board or a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Oct 07, 2013 | Frigidaire ATF6000ES Front Load Washer
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fagor Dishwasher
ok if you have a volt meter then remove the bottom kick-plate locate the water valve take the connector off the valve set the meter to ac volts plug the leads into the connector turn the timer to fill if your getting the proper volts to the connector then replace the valve if nor reply to me
Jun 11, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
Washing Machines Logo
51 people viewed this question
Top Fagor Washing Machines Experts
Vernon Taylor
ray gallant
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
