Question about Garden
What engine oil do I use? - Garden
    New Friend:
    Problem Solver:
  • 7 Answers
Depends on the car. Most common is 10w30 unless its like a Pontiac or most brand new imports
Posted on Apr 18, 2015
  • Tony Carino Apr 18, 2015
    Champion:
  • 225 Answers
What engine is it??
Posted on Apr 17, 2015
  • 1,602 Answers
2 cycle motor oil same as a motor cycle it is call 2 stroke
Posted on Apr 16, 2015
The tork on a chevy 350 motor connecting rods
The "TORQUE" setting is below
Bolts or Parts Lube or Sealer Torque to: 7/16 Main Caps (2 bolt) Engine Oil 70 ft-lbs. 7/16 Inner Main Caps (4 bolt) Engine Oil 70 ft-lbs. 7/16 Outer Main Caps (4 bolt) Engine Oil 65 ft-lbs. 3/8 Outer Main Caps (4 bolt) Engine Oil 40 ft-lbs. Warning!!! If you are using ARP bolts, you MUST use
their specs. Click Here! 3/8 Connecting Rod Bolt Engine Oil 45 ft-lbs. 11/32 Connecting Rod Bolt Engine Oil 35 ft-lbs.
Cylinder Heads
Engine oil
(blind hole)
Sealer
(water jacket)
65 ft-lbs.
Rocker Studs (screw-in) Engine Oil 50 ft-lbs. Oil Pump Engine Oil 65 ft-lbs. Oil Pan Engine Oil 12 ft-lbs. Cam Sprocket (upper gear) Thread Locker 20 ft-lbs. Timing Cover Engine Oil 6 ft-lbs.
Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 30 ft-lbs. Valve Cover Engine Oil 3 ft-lbs. Exhaust Manifold Anti-Seize Lubricant 25 ft-lbs. Spark Plugs No Lube or Sealer 20 ft-lbs.
Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker 60 ft-lbs. Clutch Pressure Plate Thread Locker 35 ft-lbs.
Centerbolt
(Harmonic Damper)
Engine Oil 60 ft-lbs.
Bellhousing
(Transmission to Block)
Engine Oil 25 ft-lbs.
Dec 02, 2016 | Cars & Trucks
Replacing oil pan gasket 1998 chevy silverado 305 cu.in.
REMOVAL PROCEDURE
  1. Remove the oil level indicator tube.
  2. Raise the vehicle.
  3. Remove the engine oil and the engine oil filter.
  4. Remove the oil filter adapter.
  5. Remove the starter.
  6. Remove the flywheel inspection cover.
  7. Remove the engine mount through bolts.
  8. Raise and support the engine.
  1. Remove the oil pan nuts and bolts. Note the location of any studs to assist reassembly.
  2. Remove the engine oil pan and the gasket.
  3. Clean all sealing surfaces. Refer to Oil Pan Clean and Inspect under Engine Unit Repair.
INSTALLATION PROCEDURE
  1. Install the engine oil pan and a NEW gasket. Refer to Oil Pan Installation under Engine Unit Repair.
  2. Lower the engine onto the mounts.
  3. Install the engine mount through-bolts.
  4. Install the starter.
  5. Install the flywheel inspection cover.
  6. Install the engine oil filter and the engine oil.
  7. Install the oil filter adapter.
  8. Install the oil level indicator tube.
May 04, 2015 | 1998 Chevrolet Chevrolet silverado
How to change a fuel filter on a polo vivo 2010
Engine oil: Drain or extract and replenish; renew oil filter Engine oil: Drain or extract engine oil ? Chapter. Renewing oil filter ? Chapter. Replenishing engine oil ? Chapter. Draining or extracting engine oil Special tools and workshop equipment required t Used oil collection and extraction unit -V.A.G 1782- t Oil spill cloth -VAS 6204/1- Draining or extracting engine oil Carry out the following procedure: > Note
t For engines with standing oil filter the oil filter must be renewed before changing the engine oil. When removing the filter element a valve is opened, the oil in the filter housing automatically flows into crankcase. t If the engine oil is drained and not extracted with an oil extractor, replace drain plug. This prevents leaks. t Observe disposal regulations! - Extract engine oil using used oil collection and extraction unit -V.A.G 1782-. or - Remove oil drain plug. - Let engine oil drain. > Note
t The oil drain plug is fitted with a secure seal, therefore the oil drain plug must always be renewed. t Observe disposal regulations! - Screw in new oil drain plug with seal hand-tight. - Replenish engine oil, specification ? Chapter. Engine oil capacity: "Power unit" ? Power unit; Rep. Gr.17"Lubrication; oil capacities" or ? Maintenance table. Specified torques for oil drain plug: t Petrol and diesel engines 30 Nm > WARNING
t Torque specifications must not be exceeded. t Excess torque can cause leaks in the area of the oil drain plug or even damage. Renewing oil filter Renewing oil filter, 1.4 l and 1.6 l injection engines > Note
t Prevent engine oil from dripping onto components in engine compartment. t Oil new O-rings before installing. t Observe disposal regulations! Renewing oil filter, 1.4 land 1.6 l engine Carry out the following procedure: alt="W00-10211"> - Unscrew cover cap -1- with socket insert 36 mm AF and remove cover with oil filter insert -4- and valve -5-. - Renew O-ring -2- of cover cap and O-ring -3- of valve. - Renew used oil filter element with new filter element. > Note
Observe disposal regulations! - Tighten cover cap -1-. Cover cap torque setting: 25 Nm. Replenishing engine oil Oil specifications ? Chapter Engine oil capacities: "Power unit" ? Power unit; Rep. Gr.17"Lubrication; oil capacities" or ? Maintenance table. General notes > Note
Observe disposal regulations! - After replenishing with oil, wait at least 3 minutes and then check oil level. - Pull out dipstick, wipe with a clean cloth and push dipstick in again to limit stop. - Pull dipstick out again and read oil level. alt="N01-10183"> For dipstick as illustrated: A - Oil must not be replenished. B - Oil may be replenished. It may happen that the oil level afterwards is in the -A- region. C - Oil must be replenished. It is sufficient if the oil level is in the -B- region (hatched area) afterwards. There is a danger of damaging the catalytic converter if the oil level is above the -A- marking. - If oil level is below -C- marking, top-up oil to -A- marking. alt="N01-10255">
Mar 14, 2015 | Volkswagen Polo Cars & Trucks
How to replace oil; cooler on this year
  • Service and Repair
Oil Cooler Replacement
Removal Procedure
  1. Raise and support the vehicle. Refer to Vehicle Lifting.
  2. Drain the engine oil and remove the oil filter housing.
89116492
  1. Loosen the oil cooler outlet (1) and the inlet (2) lines from the engine block.
  2. Lower the vehicle.
  3. Remove the intake plenum.
  4. Remove the intake manifold.
89116493
  1. Disconnect the following electrical connectors from the water crossover:
    • The engine coolant temperature sender (2)
    • The engine coolant temperature sensor (4)
84936658
  1. Remove the water crossover bolts (1).
  2. Remove the water crossover upper and lower seals (2).
84942881
  1. Loosen the upper heat shield bolts on the left side of the exhaust manifold.
89116496
  1. Remove the oil cooler outlet line from the engine oil cooler.
  2. Remove the oil cooler inlet line from the engine oil cooler.
84942883
  1. Note the positioning of the 4 seals.
84972057
  1. Position the oil feed and return,lines out of the way and secure with mechanic wire.
  2. Remove the engine oil cooler, inlet and outlet nuts (1).
  3. Remove the engine oil cooler cover bolts (2).
84942883
  1. Remove the engine oil cooler cover.
  2. Remove the engine oil cooler.
Installation Procedure
84972056
  1. Install the engine oil cooler.
  2. Apply a 2 mm (0.08 inch) bead of RTV silicone sealant, GM P/N 12346240, in the groove around the engine oil cooler cover.
  3. Install the engine oil cooler cover.
Notice: Refer to Fastener Notice in Service Precautions.
84972057
  1. Install the engine oil cooler cover bolts (2). Tighten the engine oil cooler cover bolts to 30 Nm (22 ft. lbs.).
  2. Install the engine oil cooler inlet and outlet nuts (1). Tighten the engine oil cooler inlet and outlet nuts to 20 Nm (15 ft. lbs.).
  3. Reposition the oil feed and return lines.
84942883
  1. Install the oil cooler outlet and install the oil cooler inlet lines to the engine oil cooler. Use 4 new seals.
Tighten the oil feed and return lines to 30 Nm (22 ft. lbs.).
84936658
  1. Install the water crossover:
    • Position the crossover.
    • Install the upper and lower seals (2).
    • Install the water crossover bolts (1). Tighten
Tighten the water crossover bolts to 30 Nm (22 ft. lbs.).
  1. Connect the electrical connectors at the following locations:
  1. Install the intake manifold.
  2. Install the intake plenum.
  3. Raise the vehicle.
89116492
  1. Install the oil cooler outlet (1) line to the engine block. Tighten the oil cooler outlet (1) line to 30 Nm (22 ft. lbs.).
  2. Install the oil cooler inlet (2) line to the engine block. Tighten the oil cooler inlet (2) line to 30 Nm (22 ft. lbs.).
  3. Install the oil filter housing to the engine block. Tighten the oil filter housing to 45 Nm (33 ft. lbs.).
  4. Lower the vehicle.
Dec 22, 2014 | 2001 Cadillac Catera
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
May 14, 2011 | Ford Focus Cars & Trucks
What type of oil and how much do I use with the honeywell 1000w generator?
Engine Oil Recommendations
Use 4-stroke oil, or equivalent high detergent, premium
quality motor oil certified to meet or exceed U.S. automobile
manufacturer's requirements for API Performance
Class SF or better. SAE 15W-40 is recommended for general,
all-temperature use.
NOTICE
Engine oil is a major factor affecting engine performance
and service life. Non-detergent and 2-stroke engine oils will
damage engine and are not recommended.
• Be sure to use engine oils specified under "Engine Oil
Recommendations."
It is very important to maintain proper level of engine oil to
keep engine in good running condition.
• Check engine oil level prior to each use. Refill engine
oil if oil level is low.
FIGURE 17: Recommended Oil Viscosity
Crankcase pressure can cause hot engine oil to
spray out of engine fill hole. Hot engine oil can
cause severe burns.
• ALWAYS stop engine before removing the oil fill cap.
15W-40
WARNING
FIGURE 18: Oil Fill Cap Removal
FIGURE 19: Oil Fill Measurement
Oil Capacity [qt / ml]
HW1000i 0.26 / 250
HW2000i 0.48 / 450
TABLE 4. Engine Oil Capacity
Mar 08, 2011 | Garden
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2001 Dodge Durango
How to replace oil pump
REMOVAL & INSTALLATION
Gasoline Engines
See Figures 1 and 2
Fig. Fig. 1: Exploded view of the oil pump used on 2.0L and 2.3L gasoline engines
Fig. Fig. 2: Exploded view of the oil pump used on the 4.0L engine-2.8L and 2.9L engines are similar
  1. Follow the service procedures under Oil Pan Removal and remove the oil pan assembly.
  2. Remove the oil pump retainer bolts and remove the oil pump.
To install:
  1. Prime the oil pump with clean engine oil by filling either the inlet or outlet port with clean engine oil.
  2. Rotate the pump shaft to distribute the oil within the pump body. Install the pump and tighten the mounting bolts to 14-21 ft. lbs. on 2.0L and 2.3L engines; 6-10 ft. lbs. on 2.8L and 2.9L engines or 13-15 ft. lbs. on 4.0L engines.
Do not force the oil pump if it does not seat readily. The oil pump driveshaft may be misaligned with the distributor shaft assembly. To align, rotate the intermediate driveshaft into a new position.
  1. Install the oil pan as previously described. The oil pumps are not serviceable. If defective, they must be replaced.
Remember rated this.
Aug 11, 2010 | 1989 Ford Ranger
Oil capacity for 3.0 crd
Lubricants and capacities
Engine oil options
Ambient temperature range Cold climate
Engine oil grade SAE 5W/30
Engine oil classification API/ACEA CI/C3
Ambient temperature range Moderate climate
Ambient temperature range Hot climate
Engine with filter(s) litres 9,5
Jan 25, 2010 | 2006 Jeep Grand Cherokee
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
