Question about Verbatim SNS1TB Store n Save 1 Terabyte 1TB SuperSpeed USB 3.0 3.5" External Hard Drive Black
Manual has disappeared
I cant find the manual on the hard drive. It seems to have disappeared. actually everything that came loaded seems to have gone. I can put files on it though
My computer displays the normal windows with its desktop icons but automatically shuts down. there's a dialog box that appears but i cant read the content because it disappears in a flash, what do you...
when your desktop loads, click on start menu, run, and wright: cmd
then wright: shutdown -a (in the command promp)
and hitt enter.
the dialog should disappear, restart the pc and check if it comes again that u need to make the same prosses again plus, going to msconfig (righting it in run), and then to the bookmark saying start up and uncheck any suspisious programe, locate its files,delete them,apply and restart again.
May 12, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
Power is always on, but sometime my Toshiba
go to my computer/ dont just wait for it to appear
Jul 30, 2009 | Toshiba Computers & Internet
I can't seem to uinstall the deep freeze on my pc
Reformatt everything using the original install or backup CDs
Jun 11, 2009 | Computers & Internet
Folder unreadable and corrupted. files lost.
hey down load PCI recovery for recovery of files
May 25, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
New hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Pavilion ze2000 Notebook
Scandisk Cruzer has loaded but can't be seen in My Computer
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Question about hard drive compatibility for Creative Zen Vision M
It should work but if you wanna be safe try deleting everything off of the ipod drive first. If you do a google search it seems many people are not only removing the hard drive but actually putting in much bigger hard drives. ( up to 100GB). The only thing ive noticed is that if its a SLIM version then it may not work as a few websites have said that they cant perform upgrades on the slim versions.
May 01, 2008 | Creative Labs Zen Touch MP3 Player
My hard drive is not working
is the system load the bios or nothing happen ? In this case the system not detected the memory maybe the memory lessen, fix it firmly and start the system again.
disregard the solution above if the harddrive is detected in the bios. there is a four connection in the IDE /PATA hard drive.
P master
P Slave
S Master
S Slave
if you connect or use one IDE cable in two connection, the other should be in slave. master is where the Operating system is.
try to verify the hard drive label for a master or a slave harddrive.
If this solution not solve, please notify me b4 u rate so that i can give you further solution. thanks!
Jan 28, 2008 | Western Digital 320GB MyBook External USB...
Verbatim SNS1TB Store n Save 1 Terabyte 1TB SuperSpeed USB 3.0 3.5" External Hard Drive Black Logo
61 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
