Question about Xerox DocuColor 242-252-260 PS
Can you adjust the fold position on a Xerox Docucolor?
I am doing a saddle-stitch booklet, but I need to adjust the fold since it's about an 1/8" off. I don't see a setting on the machine to change like I can on a Canon Imagerunner.
    Master:
  • Xerox Master
  • 563 Answers
The only way I know is to tell the machine to trim off 1/8 more of the cutting edge. This is none in the driver itself not the machine.
Posted on Dec 22, 2017
SOURCE: Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Posted on Oct 17, 2008
  • 2072 Answers
SOURCE: xerox docucolor 3535 116-321 error
Unplug the ethernet cable, If it does not come up with the code then.
Search for something like internet printing turned on somewhere.
That's a freaky code that normally is associated with some odd ball print job being sent to the printer, or something trying to access the network address. It is a pain sometimes to diagnose.
Posted on Mar 18, 2009
SOURCE: I have a Xerox Docucolor 1250 displaying fault 3-380
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=DC12CP&Xlang=en_US&Xcntry=USA&ripID=XRIP_Splash_G620
http://safemanuals.com/annexe_DOCUMENT_XEROX_DOCUCOLOR%2012-_E.htm
have a look in the manuals above it shows you how. http://www.partsdrop.com/techinfo/enx_DC12info.pdf
http://www.retrevo.com/support/Xerox-12-Copiers-manual/id/8117ci661/t/2/
At that last above link are all manual that will help you and show you how to do it.
www.partsdrop.com/techinfo/enx_DC12ctg.pdf
http://www.enxmag.com/2007/new%20site%202007/website/2010%20months/AD%2021001/article_bhorvat_xerox%20dc12%20style%20fault%20codes%20revisted%20_jan2010.ht
Posted on Apr 23, 2010
wrinaldo
  • 185 Answers
SOURCE: Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Posted on Nov 22, 2010
  • 5370 Answers
SOURCE: Xerox DocuColor 3535 Copier Problem
116-325 RAP An error occurred in ESS fan rotation:---------Try reset procedure:-- to correct your issue:
Simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel.
If the problem persists try:
Hold the 6, the Stop, and the Power Save buttons.If still it comes again,---------
Hold the 4, the Stop, and the Power Save buttons .If still it comes again ,-------
Hold the 3, the Stop, and the Power Save buttons .If still it comes again then there is internal problem with cooling fan .The ESS fan module has to be replaced.The part number for ESS fan module is
127K32920.To order this part you can order it from online website.click this link directly to order the parts:---
http://www.iteminc.com/parts_docucolor_1632_2240.htm
this will help.Thanks.Helpmech.
Posted on Jan 21, 2011
How to copy a booklet on the canon 3045
To make a stapled or folded booklet on the 3045 will require the "Saddle Finisher option. This is a finisher the attaches to the left side of the copier. It has 2 trays and an additional tray on the very bottom of the finisher. If you do not have this it will be impossible to make a booklet that is two sided with the pages properly sequenced. If you have the saddle finisher attached. On the screen select special features and on the first or second screen you will see a booklet button, press that and follow the prompts. If the booklet button is greyed out you do not have the Saddle Finisher.
May 18, 2010 | Office Equipment & Supplies
Making a booklet out of a multi-page PageMaker file
many questions, the answer should be yes and all is in the driver settings but it all depends on if you have the correct driver installed and configured correctly for your copier and if your finisher is a booklet finisher. if you have every thing laid out in page maker correctly and the driver is setup correctly then it should do just fine.
Apr 14, 2010 | Canon imageRUNNER C3170U Color Copier
Canon 3200 - trying to do booklet printing, saddle stitch. The booklet should be 2 pages total (stitched together) but only one page comes out (with no stitch since it is one page) and a page of my...
Are you sure that the original documents fed through properly? If the document feeder double feeds then the machine will think that there is only one document, the first one. If the machine does not through up an error then this may well be the problem. Check with normal copying first. Also remember, you would need at least 5 or more documents to make a booklet as each page has 4 A4 pages reduced to A5.
Jun 24, 2009 | Canon imageRUNNER C3200 Copier
What does saddle stapling mean?
Saddle stapling is making a book of pages by stapling the spine at the back of the document to keep many pages together.
Apr 28, 2009 | Canon imageRUNNER 2200
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Apr 11, 2008 | Xerox Office Equipment & Supplies
How do i make a booklet?
Select BOOKLET function, found in SPECIAL FUNCTIONS. Select which size paper is required and then select FINISHER to select STAPLER and SADDLE-STITCH, then load your document into the document feeder. Select number of copies then press start button. All of this is only applicable if a Finisher and Auto-Doc Feeder is installed. Let me know if this helps?
Mar 14, 2008 | Canon imageRUNNER C3220 Color Copier
Computers & Internet Logo
372 people viewed this question
Top Xerox Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
JC Meredith
JC Meredith
Mark Magill
Mark Magill
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
