Question about Health & Beauty
What is the 3 prong round plug that's on the joystick for.
That is a charge jack.
Posted on Jul 17, 2015
How can I determine whether the on-board charger is working?
The m51 is notorious for failure of the on-board charger. An easy check would be to plug an off board charger into the 3 prong female charging receptacle at the front of the joystick to see if you can bring the voltage up. You can test the on board charger with a voltmeter at the battery connections or charger joystick port with the charger plugged in. Hope this helps
Jan 13, 2016 | Invacare Pronto M51 Power Wheelchair
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
I need to know how to charge the batterie om my sisters merits wheelchair,i do not know how to plug it up,,or if the charger is located on the frame someplace or if its freestanding.plain and simple i do...
sking the off board charger is a 5 inch by 3 inch rectangular box with a power plug on one end and a round silver 3 prong plug on the other. The charger plugs into the charger port located under the front of the joystick. Plug the charger plug into the joystick and then into the wall socket. When it is fully charged the light on the chrager will turn from yellow to green. Unplug the power from the wall socket first then unplug from the joystick In ither words always have the charger unplugged when you plug the charger up to the chair Now if the chair has an onboard charger there should be a power cord that just plugs into the chair usually somewhere in the rear of the chair all you have to do is plug it into a wall socket and charge away Hope this helps you
Mar 10, 2011 | Electric Mobility Merits Electric...
Can i use 220voltage for hp pavilion dv-2145dx Entertainment notebook?
Check the manufacturer information on the bottom of the AC Adapter. Most likely the INPUT will be
AC110~240V / 50~60Hz which means that you can use it on 220V as it is within the INPUT voltage range. The AC line frequency can be from 50 Hz to 60 Hz. You will need an adapter for the AC plug itself to go from the flat prongs used in North America to the round ones used in Asia/Europe. Also, the adapter will be needed as the wall socket likely will not accommodate the round ground prong that is present on the original three-pronged AC plug that is used for North America.
Feb 19, 2011 | HP Pavilion dv4000 Notebook
A friends mom died and he gave me her chair, ? where do you plug it in to charge the batteries
under the front of the joystick there is a 3 prong recepticale for the charger Hope this helps
Dec 10, 2010 | NRS Hoveround MPV 5 - Used Power...
What is the 3 prong outlet on the side of my chair for? Is it a charger?
If you have an on-board charger for your power chair this outlet is for your charger cord. One end of the AC cord plugs into the wall outlet and the other end plugs into the trapezoid shape outlet on the side of the chair. This is the same shaped AC cord used to power computers and other devices. You can buy one a most hardware stores and places like Radio Shack. If you are using an off board charger which plugs into the front of the joystick (round plug)to charge the chair, then you don't need to use the on-board one and you don't need another AC cord. Hope this helps.
Dec 04, 2010 | Jet 3 Ultra Power Chair
I have an hfd-135 air purifier but i can't tell if it's 110 or 220 volts.
View the electrical plug.
A 120 Volt plug has two elongated prongs on one side, with a smaller round prong for your ground, on the electrical plug.
A 220 Volt plug has two elongated prongs, but each will be opposing each other in the middle, but tilted towards each other at the top. Also, on a 220 plug, the third prong will not be round, but flat, and in a horizontal position.
Nov 15, 2010 | Health & Beauty
My joystick will not respond.
you have to plug the round tipped courd into the slot in both controllers, connecting both. you only plug one thing into your computer and that is the usb cord built into the throttle control.
Nov 16, 2009 | Saitek X52 Flight Control System
Health & Beauty Logo
203 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
