Question about Makita Tools & Hardware - Others
Will only run if battery is not completely engaged but battery works fine on all other tools
How do you test and/or replace a clutch for an EZ4824?
sounds like it could be the clutch!!!!!!
Sep 11, 2014 | Garden
Auger engages buts stops when it hits snow
Check to see if it has sheared a key.
Feb 03, 2014 | Garden
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
I have an HP ProBook 6445b laptop. This has happened twice. Battery worked fine, one day drained completely, then wouldn't recharge. Got a new battery... same thing... worked fine, drained completely,...
Before you installed your new battery did you fully charge the battery. If you do not do that you run the risk of burning out your battery cells.
If you can go into your setup when the computer first comes on, go to drop down menu tabs until you see something for the battery. You can run the this program so the battery can get use to the amount of time you spend on the computer.
Mar 27, 2011 | Computers & Internet
Starter is good,i turn key starter will not engage
Make, Model, Engine, # of miles?
Do you mean the starter runs but does not engage with the flywheel or grinds?
OR
Do you mean the engine turns over (starter works fine) but it will not start?
If it is the former you likely need a new starter solenoid or complete starter (no all solenoid are available sperately)
If it is the latter, you need to check for fuel pressure and spark.
Feb 18, 2011 | Oldsmobile Delta 88 Cars & Trucks
Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Jul 31, 2009 | Husqvarna Garden
Engine Will Not Crank
I would check the alternator and you can do this yourself if you can get the car running once you get it running and while it is running take the positive side cable of the battery off and if it dies then it is the alternator
Jan 11, 2009 | 1993 Ford Ranger SuperCab
Tools & Hardware - Others Logo
24 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
