This tv set LGcz20E60 switches itself immediately or seconds after switched on and tv repairers tells me that there is no fault on the tv set please help
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Sounds like loose solder terminal/s at its circuit board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 17, 2015
snakehead
  • 1074 Answers
SOURCE: Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Posted on Apr 26, 2007
SOURCE: TV turns on, then immediately off again
The flyback transformer are damaged.
Posted on May 28, 2008
SOURCE: set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Posted on Aug 08, 2008
  • 4 Answers
SOURCE: BUSH ID - HD TV
Try Checking your remote and make sure it did not short out by taking out the batteries and see if it continues turning on and off. if so then i would recommend replacing the remote. if this does not work try putting tape over the ir receiver and see if it continues, this will check for interference.
Posted on Nov 05, 2008
  • 6 Answers
SOURCE: assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Posted on Dec 05, 2008
When I switch on my LG ( model: 29FX4BLE-TG tv it shows white horizontal lines then immediately after few seconds it turns off by itself.
Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in this key phrase "My service table today" in its search box at the top right of the display window. You'll get some practical cases and its rectifications to this type of fault.
Jul 15, 2015 | LG Televison & Video
When you switch the TV on with the remote or on the TV. The TV comes on for a few seconds or minutes then switches itself off. The red light on the front of the TV flashes. Please HELP. Thanks Mary.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Apr 15, 2015 | Televison & Video
Samsung 40" LED TV Display
Not familiar with this particular model of samsung LED TV, but ghosting and shadowing are usually an accepted manufacturer's defect.
If you're still under warranty or within 30 days of purchase, contact the company that sold you the TV or Samsung warranty department.
If you're out of warranty and you don't wish to deal with this, contact a TV repair shop. They will most likely tell you that it's not worth repairing and recommend you purchase a new TV.
Mar 11, 2011 | Samsung Televison & Video
The tv immediately turns itself off after i try turning it on. it doesnt matter if i use the remote or turn the tv on manually. It just makes the noise as if its turning on and then immediately switches...
Hi, The TV is shutting down because there is an internal fault, there is more likely a panel that needs replacing or a few faulty components.
It's more than likely repairable.
If it's under warranty contact your dealer for repair or replacement.
Feb 10, 2011 | LG 60PS60 60 in. Plasma HDTV
Tv shuts off immediately
check first for the contact point of your control panel button maybe the tact switch is shoted specially when your always using remote control for function operation.second check power supply for leak capacitor or change in value,check also the photo coupler for leak test or change in actual.
Aug 01, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Set wont turn on red light just keeps blinking
Aug 08, 2008 | Sony Televison & Video
Tv fault
your tv switch might not be contacting the switch on the actual tv itself
Mar 19, 2008 | Sony PlayStation Portable (PSP) Console
Power button
No, you cannot disconnect the power switch. A defective power switch will not make the set turn on and off by itself, because the power relay is actually controlled by the microprocessor. The microprocessor in your set is trying to start the set but immediately detects a fault somewhere and shuts the set back off. This can be a difficult problem to solve and the set should be serviced by a qualified tech.
Aug 17, 2007 | JVC AV-32D305 32" TV
Apr 25, 2007 | Grundig GF70-600 TV
Televison & Video Logo
Top Televison & Video Experts
