I jut turned the telly on, iv got sound no picture.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 16, 2015
I turn on tv. There is sound but no video.
hi, if you have a device plugged into the telly that gives you the picture such as sky or cable then the best thing to do is disconnect this device from the back of your telly then switch the telly and this device off at the mains, then re-fit all the cables making sure they are connected properly then switch it all on.
now check if you have sound also make sure the tells is on the correct input for that decice and also make sure the mute button has not been pressed on the telly remote or on the remote of the device you use to watch telly, if after doing all that it still dont work then the chances are something has blown on the amp in the telly.
make sure you double check all the leads going into the telly to rule out a faulty lead causing you the problems
Jul 13, 2010 | Televison & Video
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Why is there no picture on my xbox only sound
hi, you can try unplugging the lead from your telly and also from your xbox then with your xbox switched off at mains plug them back in make sure you push it into the telly far enough as this could be your problem also make sure its fitted in xbox properly the problem is usually the telly end so make sure this is fitted correctly, then switch it on and see if it is now working, if it isnt then the chances are your going to need a new lead, if the problem was with the xbox then you would have no sound as well so the problem points towards the lead being at fault.
Also make sure the telly is on the correct channel
Mar 26, 2010 | Microsoft Xbox 360 Console
Hi, i have a ps one i want to connect to my tv via the aerial. iv plugged it in and checked the av channels but cant find it, is there anything i need to do?
Hi, right now as your plugging it in via the aerial socket then this means you wont be using any of the input channels or source channels such as av ok.
now what you can try is when its plugged in and switched on go through the channels on the telly using the telly remote try channels you dont use such as 0 6 7 8 9 10 if after trying these you still have no picture then you need to put the telly on a channel you dont use say 0 then make sure ps is switched on with a game in then on telly remote choose menu or setup then you need to use the tv setup function to search the frequency as if you are tuning a channel in so do this till you see the game then store it onto that channel, now when ever you want to play the ps you just plug it in and put it on the channel you tuned in.
or an easier option would be to go to the well known auction site and buy a ps1 scart lead then when you plug this into your telly you just choose av1 or av2 and then you can play it without tuning the channel in so this owuld be the easiest way
let me know if you have any problems
Feb 08, 2010 | Video Game Consoles & Games
I bought my ps3 in january 08 its a 40gb a couple of days ago i went to play it the sound is fine but the picture is not coming up i took it to my neighbours and it didnt work on his telly either i think...
You can have it repaired at:
PS3 Yellow Light of Death Repair using Infra Red UK
or if you have the receipt, you can have it replaced under the Sale of Goods Act. Anywhere up to 6 years after the date of purchase.
To do this you just need:
Independent PS3 fault report UK
Stating that the fault was there at time of manufacture.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
LG FLATRON PLASMA TV PICTURE KEEPS GOING RED
starting with screen, there is a problem with HV transformer and just an expert can fix it. The sound's problem is from your jack's cable. Replace the Jacks and there no must be the problems! Rateme if i've help you. Thanks!
Sep 14, 2009 | LG Studioworks 700S 17" CRT Monitor
Unit intermittently makes the TV flicker the sound and picture.
I would be checking and trying new leads from the antenna part of your telly to where they go into the wall , we had a problem with a new tv that used to turn itself off and on we got the tv replaced with another new one and it still did it . it turned out to be a faulty cable from the pay tv box on top of the telly as they emit FM waves just like the radio and it was sending signals to the remote on the tv to turn it off
May 17, 2009 | Samsung HT-WX70 Theater System
X box stays on and telly blurryy but showing the picture?
It sounds like bad soldering, your tv doesn't freeze it's your xbox video/audio output that does. Did you use the towel trick, that is one possible way to have gotten it. You should send it to Microsoft for repair.
Mar 14, 2009 | Microsoft Xbox 360 Console
Cleaning rear projection screen
I read in the manual for the Sony KDF 50E3000 that you should use warm soapy water on a clean cloth if you aren't able to remove it with a dry cloth. I find that the microfiber cloths work best.
Feb 11, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
