Question about Garden
Front end broke out from under tractor while mowing I need a diagram of front end so I can repair it
    Sergeant:
  • Garden Expert
  • 187 Answers
    Top Expert:
  • Garden Master
  • 52,123 Answers
Google make and model .since we have no idea what you have
Posted on Apr 16, 2015
Craftsman Garden Tractor 26 HP 6 speed transaxle First mow of the season. mowed 15 ft. pressed in clutch to look behind at how it was mowing let clutch out to go no forward movement. belt seams good.
Make sure the transaxle disengagement lever is not in the neutral position. On most lawn tractors, this lever is a stiff wire -- sometimes with a loop on the end -- that sticks out of a slot above and to the right of the trailer hitch bracket on the rear panel, below the seat. Most tractors move under their own power when the wire is all the way in, and can be rolled around without the engine running when the wire is pulled out.
Apr 10, 2018 | Craftsman Garden
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Looking for diagram on front end
Go Here:
Husqvarna YTH2348 96043005901 Riding Lawn Mower Parts
I have no connection with erepair but I buy parts from them all the time. good prices, excellent service. Great for the DIY.
Apr 16, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
38 in deck murray riding mower. Apparently a spring broke from under the deck. I'm not sure what it is for. I found the spring in my front yard. So I was able to continue mowing. I mowed my whole back...
Its probably from a tensioner pulley. If you take pics and post along with make, model and serial number I could look up specs to see where its missing from. To answer your question, no it shouldn't hurt anything. But, everything is on your unit for a reason, you may throw a belt or something. Hope this helped!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 12, 2013 | Garden
I was mowing and all of a sudden it stopped steering. The front left wheel moves when I move the steering wheel. The front right doesn't. I can move the front right without moving the steering...
Sounds like the tie rod has came loose or broke, look for a rod that connects the working wheel to the steering and then compare it to the non working side and you will be able to see what is missing
Jun 27, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a Huskee lawn tractor and as I was mowing the drive pedal stopped working. A spring broke and was still hanging so I know where one end a new spring will attach, but I do not know where the other...
Go to a website that sells parts for huskee you may have to go to mtd.com and find parts diagram for the deck, hopefully you can find your spring location.
Aug 04, 2017 | Garden
I need to install a new drive belt on a GT 275 Belt broke while mowing. Got new belt but it is not obvious how it goes on.
lay under the mower and look for a diagram - there should be one somewhere on the unit.
Gary @ Fix Ya
Sep 19, 2010 | John Deere Hood Gt242gt262gt275 Garden...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
