Question about LG Washing Machines
Fuzzy Logic 8.5Kg WF-T857 Turbodrum. How do you clean your machine and can you replace the fluff pockets?
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Your owner's manual will show the amount of bleach your size tub requires. Run the machine on normal cycle that you use but do not add washing powder or fabric softener, only the bleach.
When the cycle has ended, open it up and allow to air dry.
The lint filters are replaceable and are available from your nearest LG service center or distributor.
Posted on Apr 18, 2015
4 Suggested Answers
SOURCE: LG Fuzzy Logic WF-T7030TP Turbodrum Sensor
Error Peurta
Posted on Mar 24, 2008
  • 714 Answers
SOURCE: My machine did not spin out the water, maybe there
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Jan 03, 2010
  • 18 Answers
SOURCE: i have a lg fuzzy logic 7.5 kg WF-T755A washing machine that has stopped spinning and also stopped agitating in washing cycle
Call LG's support line, they have excellent customer service.
Posted on Apr 04, 2013
Where can I find the belt tensioner on a LG FUZZY LOGIC 8.5KG WF-T857 washing machine
the motor id mounts are slotted so lossen those and you can adust the belt tension that way, warning the belt id supposed to be loose if over tightened you will ruin the bearins in a very short space of time
Nov 29, 2017 | LG Washing Machines
Lg turbodrum fuzzy logic 7.0 wf t700 showing error code "de" what that is mean? And how to fix it?
Try unplugging power, push and hold power button for 5 seconds, then plug back in. See if error code is gone.
Nov 05, 2017 | LG Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG Fuzzy logic for a year and a half now, model WF-8071TTP top loader. it seems that after washing all my clothes are full of fluff. I have cleaned out the filter bag, and all little filters at...
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
Jan 17, 2011 | LG WFT1071TP Top Load Washer
Oily substance
most common is lint build up. a good hot wash with a good bleach...check your manual for manufacturer's recomendation. There's various products available..bleach is the most in-expensive and works well. make sure its set on high water level...pause machine for 10-20mins...let me know how you get on
Jan 03, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
263 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
