Question about CH Open-Head Plastic Drum- labeled as picture B BOH-55
Having three grey bars when playback
hello, wow .....is it horizontally bar? if yes that mean :
1. the head drum have two channel reading that is Ch A and Ch B
one of them there a dead channel, try to change head drum that
will solve your problem.
2. your head drum may dirt, cleaning using paper and alcohol and let it dry naturally. do not insert cassette before you using cleaning cassette. and i hope it will work.
thanks
otto
Oct 09, 2013 | Sony Handycam DCR-TRV740 Digital Camcorder
How to remove the head of a stihl km 55
need more info... which head?? what are you trying to do??
Aug 26, 2012 | Stihl Km 38 45 46 55 Trimmer Clutch Drum
I have a DCP-7040 Brother Laser printer. I am getting a lot of black lines when i print. I have tried cleaning the head of drum but that did nothing.
Two likely possibilities:
1. The drum is scratched by particles caught under the drum cleaning blade. Every copier or printer that has a drum leaves a little bit of toner on the drum that didn't get transferred to the paper. A soft plastic blade scrapes off that excess. If a chunk of fused toner or something gets caught under it, it can scrape a groove around the drum, resulting in a black line. Take a close look at the drum for scratches matching the lines you get. The cure is a new drum unit.
2. The fuser roller is scratched. Open up the back of the printer. The fuser is the assembly with labels warning about how hot it is. The final stage of the print process is to press the page between those two hot rollers, melting the toner into the paper. The hot roller is coated with Teflon to prevent pulling toner off the page and laying it back down where it doesn't belong, but like the drum, it can be scratched. You might be able to look for scratches on the hot roller with the help of a strong flashlight and magnifier. If it's scratched, you need a new hot roller or a complete new fuser.
Let us know what you find.
Apr 21, 2010 | Brother DCP-7040 Laser Printer
"CH" is blinking
CH is a door open?Open side door before you open the front door,check that drum,dev & toner unit is installed if this doesnt solve it push the righthand door downwards so that the switch makes connection.
Aug 18, 2009 | Sharp AR-164 Copier
Mitsubishi 55" - Stretches screen
on the frount you should have ch up , ch down,
same for volume , and menu. press menu
and scroll down to VIDEO or SET UP
try one of thoes sub menu will have FORMAT
4:3 - 16:9 seting its a little differant on
on same make diferant models , you may
have to do a little hunting to find the setting
Jul 02, 2009 | Mitsubishi WS-55807 TV
Jammed Photocopier
you need to remove the drum unit out of the machine,and take cotton rag use achohol ..rotate the drum clock wise until you see the label that stuck on it..
good lock
Feb 28, 2009 | Lanier Office Equipment & Supplies
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Head sensor problem
the sensor(printhead and media sensor) from the print head is the metalic plate next to the black plastic(gap sensor) sensor unther the printhead on the left side.
try to push up the sensor, some times is hard but can be the solution.
Apr 24, 2008 | Zebra Z4Mplus Label Printer
Jammed Photocopier
I would suggest that a label came to be attached to the photorector drum. Unless you can remove this label the problem will continue
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
CH Open-Head Plastic Drum- labeled as picture B BOH-55 Logo
571 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
