Question about HP Color LaserJet CM2320fxi All-in-One, Copy/Fax/Print/Scan
How can I reset the Admin password, as it is not available.
This used to be a network printer and protected with a password which is not known anymore. Anyone has some idea. I alreday used the Cancel + Right Arrow or down arrow method but in vain. Any other suggestion to bypass the Admin password to get to the settings.
  • 1019 Answers
SOURCE: Permanent white arrow cursor
Try This:-
1:- Press And Hold The Contacts And Mail Buttons.
2:- Then Doing a soft reset, you should be prompted with To perform a clean reset, Press the Calender Button.
Mike @ Compurepair.
Posted on May 12, 2008
fidoliedo
  • 162 Answers
SOURCE: When trying to scan, 7210 doesn't see/recognize networked computers
From each computer, you need to run the HP Director. When opened, click on SETTINGS, then SCAN TO settings to configure. This way it will transfer data to the scanner so that when at the scanner, that computer will be in the list of places to send a scan job.
Posted on Jul 25, 2008
SOURCE: Printing envelopes
If you are printing from MS Word - go into Tools - Letters and Mailings - Labels and Envelopes, Envelopes Tab, Options, and turn off the clockwise rotation check box. Seems to work for me.
Posted on Oct 16, 2008
getbharti
  • 33 Answers
SOURCE: Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Posted on Nov 28, 2008
SOURCE: camera self- diagnostic doesn't work
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Posted on Feb 22, 2009
Putting pasword
wirelessl ?
Many households have unsecured wireless networks, which can lead to hackers as well as leaks in confidential information. However, you can password-protect your wireless network by taking some basic steps.
Determine your network IP address by navigating to the "Start" menu and selecting "Run." In the Run dialog, type "cmd" (without quotes) and click "OK." The Command Prompt dialog opens. Type "ipconfig/all" (without quotes) and press "Enter." The command prompt will display a list of data for you network, including your IP address. Launch a Web browser and input your IP address in the address box. The control page of your router is displayed. Refer to the manual that came with your specific router on the manufacturer password/user name to login to your network. Usually the User Name is "admin" or "password" and the password is either "admin" or "password." Sometimes these fields are left blank. After logging into the router you can access the administrative functions. Within the administrative functions, navigate to the security settings. Within the security settings, you can change the username and password to log in to the router. Disable the router's remote administrative functions. Remote administrative functions allow anyone using the Internet to access your router. To be more secure, disable these options. The only reason to enable them is if a network administrator isn't always on location. Change the network's name. Your router comes with a default network name like WLAN or Linksys. These names are referred to as SSIDs. You want to change the name to something that you will recognize, but others won't associate with you. If your name is John, don't call your network "John's Network." Enable encryption and enter a password in the appropriate field. Wireless routers use several types of encryption, including WPA2, WPA and WEP.
At the time of publication, WPA2 (Wi-Fi Protect Access 2) is the most secure encryption format available on some routers. But you can't use this encryption type if your router doesn't support it. WPA (Wi-Fi Protected Access) is recommended if WPA2 isn't available on your specific model. WEP (Wired Equivalent Privacy is the least secure of all the encryption formats and is relatively easy to hack. If you have no other choice, use at least WEP encryption. Some protection is better than no protection.. Record your password and settings for future reference. If you lose your password, you can reset your wireless router to the manufacturer's default settings by pressing the router's "Reset" button, usually found on the back of the unit. Remember to re-secure your network after a reset.
How To Secure Wireless Networks
http://www.pcmech.com/article/how-to-secure-wireless-networks/
Apr 18, 2013 | Computers & Internet
Tip
Resetting an OfficeJet X-series Printer
Since this printer has no physical buttons, but a touch screen display there is a special way to get into service mode
Right after applying the latest firmware upgrade on a brand new HP X476 printer, All of the admin functions displayed a padlock icon, they were locked and requested an admin password. Since I had just gotten the printer, got it networked, and all the preferences set, I had not created an admin password. The update assumes you had set it and locks all of the admin functions. So I had no password set, therefore there was no password after the update. So I could not do a reset as it is protected.
After over and hour with HP Support (his name was "Bob" with a very heavy Indian accent) I got them to "give up" the way to get into the service mode to do a hardware factory reset.
Warning: There are functions in this mode that are meant for service technicians and can cause major damage. We all like to "tinker" but I strongly suggest you stick to the reset functions only.
Start from the home menu on the printer's screen. Press the "return" icon. It is not illuminated at this point. You can display it by pressing one of the main icons (copy, scan, fax, apps) and mark where it is. Press it 4 times. The servfce menu appears. press down until you get the reset menu. Select the partial reset. That should reset the printer to factory defaults.
on Jan 15, 2015 | HP Officejet Pro X476dn Color Inkjet...
Tip
Generic instruction on how to connect your WiFi Router to the Internet
Yes, try this, Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.Next, open Internet Explorer and type in the address to configure your router. You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router. As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufactures. Table is, Router Address, User Password. 3Com http://192.168.1.1 admin adminD-Link http://192.168.0.1 admin Linksys http://192.168.1.1 admin adminMicrosoft http://192.168.2.1 admin adminNetgear http://192.168.0.1 admin password
Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three things: 1. Your wireless network name, known as the SSID. This name identifies your network. You should choose something unique that none of your neighbors will be using. 2. Wireless encryption (WEP) or Wi-Fi Protected Access (WPA), which help protect your wireless network. For most routers, you will provide a passphrase that your router uses to generate several keys. Make sure your passphrase is unique and long (you don't need to memorize it). 3. Your administrative password, which controls your wireless network. Just like any other password, it should not be a word that you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings. The exact steps you follow to configure these settings will vary depending on the type of router you have. After each configuration setting, be sure to click Save Settings, Apply, or OK to save your changes. Now, you should disconnect the network cable from your computer.
on Feb 11, 2010 | Computers & Internet
I forgot admin password
To reset the SWS (SyncThru Web Service) password:
  1. Press the Menu button.
  2. Press the right or left arrow until Network appears, then press OK.
  3. Press the right or left arrow until Clear Settings appears, then press OK.
  4. Select Yes and press OK.
  5. After the printer finishes clearing the network settings, unplug it for a few seconds then plug it in again.
  6. All network settings (including the SWS password) will be reset. If you had manually configured IP info or were connected to a wireless network, you will need to re-enter those settings now.
  7. The login will default back to admin and the password will be sec00000.
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
Dec 17, 2012 | Samsung SCX-6345N Printer
I want to find out how to secure my network. My neighhbours ar loggin in on because I pay for high speed access. The router is Belkin g Plus MIMO 180170
it depends on what you specifically want to password-protect: a. protecting the network from unauthorized users? b. protecting the network's admin interface?
for a. - log into your network's admin interface (usually http://192.168.0.1) - go to the category of wireless security - select the type of network protection you are looking for (strength - i.e. wep, wap, wpa2) and set your password following the steps listed within your router's admin interface...
for b. - log into your network's admin interface (usually http://192.168.0.1) - if you have never done this before, then your username should be filled in as Admin and leave password blank and hit enter.... from there, you are able to change or at least add a password to the interface from unauthorized access (usually under category security)
Jun 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to reset mobotix camera without admin password
If you lose your MOBOTIX admin password, it needs to be sent back to the MOBOTIX factory for a reset. This is kind of like an insurance policy, to protect your MOBOTIX investment.
In this YouTube video tutorial we explain why the MOBOTIX admin password reset policy is in place and what you need to do if you lose/forget the MOBOTIX camera admin password.ord.">
Dec 15, 2010 | Mobotix Mx-m24m-sec-d22 Ip Camera Network...
My wireless modem is not working
3.Configure your wireless router
As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufacturers.
Router
Address
Username
Password
3Com
http://192.168.1.1
admin
admin
D-Link
http://192.168.0.1
admin
Linksys
http://192.168.1.1
admin
admin
Microsoft Broadband
http://192.168.2.1
admin
admin
Netgear
http://192.168.0.1
admin
password
4. Connect your computers to the wireless network If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Mar 25, 2010 | Compaq Presario Notebook
Is there anyway to get internet cinnection without having a cd driver for internet?
Yes, try this, Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router. Next, open Internet Explorer and type in the address to configure your router. You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router. As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufacture Router Address User Password 3Com http://192.168.1.1 admin admin D-Link http://192.168.0.1 admin Linksys http://192.168.1.1 admin admin Microsoft http://192.168.2.1 admin admin Netgear http://192.168.0.1 admin password
How do i set a password to protect my wireless internet
Access the Router's page and go to Wireless configuration. You may assigned a WEP key that uses hexadecimal value (A-F, 0-9). So if someone attempts to access your Wireless network, they will prompt to enter a Wep key.
Jun 05, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Missing SSID
well more then likely someone reset your router. now securing it again will depend on the model but typically from the internet explorer window type in the address bar 192.168.1.1 it will prompt you for a username and password username by default is "admin" and leave password field blank and click ok. this is for most models.(if you are not able to access this you are going to need to find the manual or get then model # and goto linksys.com to find the default password for that model"
from here click on "wireless" at the top then click on "wireless security" here you can choose the security mode either wep or wpa enter your encryption key click save settings and now your router is protected again.
If you still are having problems write back the the model # and I or someone else will be glad to help you.
Jan 03, 2008 | Linksys Wireless-G Broadband Router
HP Color LaserJet CM2320fxi All-in-One, Copy/Fax/Print/Scan Logo
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
