Question about Canon Ir 3300 Black & White Copier
Copy Quality not clear Lite Print - Canon Ir 3300 Black & White Copier
  • Canon Master
  • 5,631 Answers
If your printer's quality is not what it supposed to be , you have a problem with the printer head. If it is "user removable" like those used by HP Desk Jet printers, remove it and buy a new one. else you should take it to a technical rervice.
Posted on Apr 16, 2015
Canon IR400 print copy to black print
Most likely it's time to replace the drum unit. Mfr Part #: Canon 1342A003AA, GPR-2, F43-6701-700. Those drum units only last 55,000 copies and then the copy quality starts to degrade.
Nov 24, 2014 | Canon Office Equipment & Supplies
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
The printer prints very slowly all of a sudden. It took over an hour to print out 4 pages. I've unplugged everything. I've cleared the print ques. Same thing is happening when I copy. Help!
If the output quality has improved greatly, you may have selected the "High" quality instead of "Normal". The front panel should give you a clue as to how to adjust.
Jun 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
Noise when beginning to print or copy
Mine always makes noise too, I don't know why. But I know that it's a lot noisier when paper quality is set for draft, so you might want to check that.
If you just go into the printer properties, under the tab that's something like Paper/Quality. There will be a drop-down list where you can choose the quality of your print out, i.e. Best, Normal, Draft or FastDraft. If it's set for Draft, you might want to change it to Normal. Draft uses less ink, but it also doesn't come out quite as clear, and is very loud.
Mar 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Canon Ir 3300 Black & White Copier Logo
old marine
old marine
