Question about Yamaha RX-V373 5.1 Channel AV Receiver
My receiver just shut off while watching a movie and won't turn back on. I checked the only fuse i could find. Where to go from here.
    Genius:
  • Yamaha Master
  • 1,054 Answers
Press and hold the "straight" and "Tone control" buttons and press power. This should release the protect lock that the receiver is in. If it shuts back off immediately, then you most likely have a blown amp that will need to be repaired.
Posted on Apr 17, 2015
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Shutting off during a loud part of a movie
Its eather a defect with the reciver top end shut down /over bias system , Or the speakers could be partially shorted, such as instead of being 8 ohms, the speakers could have a few shorted windings from a loud music event?? I would take the speakers in to be checked under load. NOT just checked for resistance.. A regular shop may not know how to do this BUT tell them you need to put the speakers under a load and then measure the resistance . GOOD LUCK
Posted on Jun 25, 2006
  • 4234 Answers
SOURCE: receiver shuts off at times
There is some leakage of DC voltage getting to the output section. DC voltage will cause the protection circuit to kick in and shut down the amp. This should be a relatively simple repair and cost about $15-$30 in parts plus the local labor rate.
Dan
Posted on Mar 18, 2008
  • 1810 Answers
SOURCE: YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Posted on Jul 25, 2009
Charging indicator starts blinking when i watch movie for more than one hour on battery
A laptop won't last long without being charge, a fully charge battery should last about 1hr 30mins so charge the battery while your watching a movie next time.
Mar 29, 2012 | Computers & Internet
Jul 25, 2009 | Yamaha HTR-5560 Receiver
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
Turns off after a few minutes
Sounds like a possible power short, especially if you have speaker cables connected to the receiver but not to speakers -- leaving the ends more likely to short (even via a single thin copper strand across a millimeter or two, when the voltage peaks). The receiver's message says "Check Spkr Cables," right? (They do mean the Speaker Cables!) Most receivers have a built-in power overload detection/protection shut-off circuit to save you from such mistakes.
Jul 18, 2009 | Yamaha HTR-5850 Receiver
When watching a movie, my receiver will shut off
The only thing you can do in this case is reduce the volume, or connect speakers requiring less power to run them.
Jun 15, 2009 | Audio Players & Recorders
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
Nov 20, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Need Help
Sounds like you have a loose cable. Check that the connection is really in well. If the problem continues I would get a new set of cables, especially if you are using the ones that came with the receiver or dvd player.
May 05, 2008 | Audio Players & Recorders
Receiver shuts off at times
Dan
Dec 14, 2007 | Yamaha RX-V992
Jun 25, 2006 | Yamaha RX-V550 Receiver
Yamaha RX-V373 5.1 Channel AV Receiver Logo
471 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
