Question about Cycling
How to reset unjam the abus raydo pro bicycle lock?
How do I set an abus 1460 combination lock
Your lock is here Linda, but no instructions
https://www.abus.com/eng/Mobile-Security/Bike-Safety-and-Security/Locks/Steel-O-Flex/Steel-O-Flex-Raydo-Pro-1460
there are a number of videos showing how in the main link. This one is good;
https://youtu.be/ZyPmi1o_o1M
This one has the key built in
https://youtu.be/m32HP5E8Ak8
Go to Bing homepage
Jul 21, 2016 | Abus Raydo 1460 Lighted Combo
Have a abus comb lock its locked i put in the four numbers which are correct but it wont open only just bough it shop put in the combination
Take it back to the shop. They will provide the correct combination or reset the combination; or will owen you a new lock or refund (if you did not actually forget the combination). Abus makes good locks.
Mar 14, 2015 | Locks & Locksmithing
SNFSD14E86386
If its a new purchase still under warranty return it to Walmart. If its older or has been abused, take it to the local bike shop for correct repairs.
Aug 31, 2014 | Mongoose Mens Impasse HD 29" Mountain...
How to set combonation on Airbus Bordo Granite lock
Go on line to the manufactures web site and seek a new manual download from the support division.
May 10, 2014 | Abus Cycling
Forget security code
It Locked to security code or password lock? You can get the master reset code and reset the phone from security lock...It locked to network means use the network unlock code to Unlock the Sim Network lock,Specify the Model and brand?You can get the Network Unlock code and Master reset code at hereUnlocking4free.com and Unlock it or reset it...You can try default code as 0000 or 1234 for Nokia to unlock from security lock ,if not works get the master reset code and reset it.
Sep 04, 2011 | Cycling
Hi, I bought a Krypto bicycle lock over 5 years ago. I don't see it displayed on your website. It has yellow ends with 4 digit combination numbers red on black.The rope cable is grey and has a clear...
Krypto has the resetting of the combination lock on their website (under Maintenance) but if you cannot unlock it in the first place you can not reset the combination. You have to know the old combination to get it open.
Feb 23, 2011 | Kryptonite Cycling
Bike lock enters half way and then jams, possibly reset by accident, how do you start over and reset?
Go to masterlock.com and they should have your answer. You can recover you combination etc, so I am sure that they can help you
Sep 08, 2010 | Master Lock Bicycle Lock
Cycling Logo
190 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
