How do i Correct 0x8003002f error - Office Equipment & Supplies
How can i fix error C6101 of my BH-195?
Hi
The problem appears to be with the scanner unit
Scanner home detection failure
- When the power switch is turned ON or a scan operation is completed, detecting the home position fails. 1 Turn OFF and ON the power switch.
2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary.
3 Check M3 for correct drive coupling and correct as necessary.
4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB. You can find the page here, and it gives other error codes and their solutions as well.
Error Codes Konica Minolta bizhub 195 page 2
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Konica Minolta Office Equipment & Supplies
Error 355-001 IR2570c
Error 355-001 IR2570cYou need to put the correct boards back in the correct machines. There is a board called a serial number PCB that is linked to that specific machine. If it is transfered to another machine it will code out with that error.
Apr 30, 2012 | Canon Office Equipment & Supplies
Login error. when i try to login the word error comes up and cannot login.
Make sure you are using the correct username and password. If you are sure it's correct, contact the website to see if the error is on their end.
May 08, 2011 | Computers & Internet
I did a boot scan and three errors showed up error 42125, 42127, 42144. Is there anything that I can do to correct it? Thanks
Errors 42144, 42125 and 42127 showed on doing Avast scan before booting up. Please tell me ho;w to correct these errors
Feb 06, 2011 | Computers & Internet
I keep getting this error. Please advise what I
The link below has instructions to correct the error. Please take the time to leave feedback.
http://www.avg.com/us-en/hot-topics.num-2654
Dec 03, 2009 | Computers & Internet
Error message 5100 is displayed
Two questions.
Are you reporting the correct printer model? I cannot find the iP1300 on the Canon website.
Are you reporting the correct Error No? I cannot find an Error No 5100 on the Canon web site.
Don
Nov 18, 2009 | Canon PIXMA iP1300 Printer
540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
C++ problem BGI ERROR
The most probable reason why the program is not working is because your Turbo C++ BGI Graphics folder is not "c:\\tc\\bgi".
Correct the path and it should work.
If you're sure that your path is correct, press Alt+F5 and paste the error received.
Jan 23, 2009 | Computers & Internet
120 people viewed this question
jasbo
jasbo
