Question about ASUS Computers & Internet
I have ASUS Eee PC x101. PC display starts blinking when I connected AC adapter and battery together On battery or AC adapter only PC is working excellent.
Like as in this video https://www.youtube.com/watch?v=nt9GTRFgJzc
    Top Expert:
  • ASUS Master
  • 7,478 Answers
I would get your charger check out
Posted on Apr 17, 2015
Where can I buy a power supply for Eee PC Seashell series?
You may find asus eee pc power supply from amazon.com,ebay.com, bestbuy.com or your local shop. While i recommend you buy one from chargerbuy.com, it is a e-shop with asus eee pc ac adapters for your choice. Cheap price with a year warranty. Just use your laptop model to search the compatible charger for your laptop:
http://www.chargerbuy.com/laptop-ac-adapter/asus-ac-adapters/eee-pc-ac-adapter.html
Dec 12, 2012 | ASUS Eee Computers & Internet
Eee pc x101 won't charge
You need a new AC charger the wires wear out very often with constant plugging in and out im on my fourth one.Buy the full charger and cable.Ebay less than a tenneerr
Aug 17, 2012 | Asus Notebooks Asus Eee PC X101CH-EU17-BK...
A/c adapter voltage seashell
Yes the power adapter output is 19 volts.
These are available from these WEB sites.
http://www.fast-battery.com/replacement-for-asus-eee-pc-1005p-ac-adapter-p-90130.html?&gclid=CMPzo7b5vK4CFUcmpAodS06hLQ
http://www.ebay.com.au/sch/Laptop-Accessories-/31530/i.html?_nkw=asus+eee+pc+1005p
Feb 25, 2012 | ASUS Eee PC 900a
My ASUS eee pc gets stuck on the windows xp loading screen. i have tried starting it in safe mode, command prompt, last known configuration, pressing F8 and every time it gets to the loading screen and...
Welcome to Fixya.
I see that you're having boot issues, here are some other things that you can try :
  • Ensure that the computer is turned off
  • Unplug/disconnect all USB connections
  • Unplug the ac adapter cable
  • Carefully remove the battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter without the battery
  • Turn on the computer
If the above procedure works,then you may reconnect all devices once the computer is up and running. Otherwise, I am recommending a full operating system re install.
I hope this helps, Thanks for using Fixya.
May 04, 2011 | ASUS Eee PC 900 PC Notebook
My notebook has a white screen.what do i do.its an Asus .. nonparallel85@gmail.com
If your system wont boot up and has a white screen it might caused by a display issue. There are some ways on how to diagnose if this problem is a software or hardware problem. You can do a power drain or you could also access the bios to replicate if you have the same problem. Here are some basic troubleshooting that you can apply for this particular issue.
1. Turn off the computer.
2. Now unplug all physical connections. Remove the AC adapter from the power outlet. Also remove the battery from the system.
3. After removing both AC adapter and battery, please press the power button for 15-20 seconds.
4. Put back again the AC adapter and battery then power on the system.
Hope it helps.
Thank you for using FixYa.
Feb 17, 2011 | ASUS Eee 4G Notebook
I turn my laptop on and all i get is a black screen with a blinking cursor on the far left corner, and sumtimes the screen keeps blinking and the cursor moves upand down on at the corner also
techsupportnoel: remove your ac adapter and battery and hold the power button down for 25 seconds, after plug your ac adapter in only and turn unit on.
Dec 06, 2010 | ASUS Eee PC 1000H Laptop
My Eee PC 4G Surf wont power on what do i do
follow the steps:
1. check ur powercord & adapter.
2. if its working then check the battery, reseat the battery & check.
3. if available then check with another battery
4. if no, then remove the battery & switch on the PC in AC mode.
5. check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. if indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
Aug 17, 2010 | ASUS Eee 4G Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
