Question about IBM Personal Wheelwriter 2
Machine turns on and immediately shuts off - IBM Personal Wheelwriter 2
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
Your problem is more than likely the power supply. It may be the function board but it is usually the power supply that is the problem.
Posted on Apr 16, 2015
Bush washing machine error code 8888 what does this mean
Error code Err 08 The start/pause light, program ready light and program end light blink. The motor has failed. Shut down your machine and unplug. Turn off the tap and contact the nearest authorized service agent immediately. http://electronicshelponline.blogspot.com/
Jul 14, 2016 | Washing Machines
Canon CLC 1120 shuts off immediately. On/off flips to OFF
you had resets the power regultor of the machine press the same button then turn ON the machine when the machine came on relese your hand from the button
Jan 15, 2015 | Canon CLC 1120 Color Copier
Laser printer shuts down immediately
A laser printer that shuts itself down immediately after turning it on indicates either a loose power cable which can be fixed by pushing the power cable in properly or something internal to the printer is causing it to shut down.
If it is shutting down due to something internal, one possability is it has the wrong power going into it. a 110 volt power supply going into a 220 volt printer or the other way round change the supply or find a converter for it. Another possibility is some other component in the machine is failing such as the power regulator board or format board. If it is something internal like this. Replace the printer is really your only option unless it is still under warrantee as replacing parts in most machines nowdays is more expensive than buying a new printer.
Aug 19, 2014 | Brother HL Office Equipment & Supplies
Printer immediately loses power when turned on. All lights light up and then machine immediately shuts down. Like there is a short or fuse problem.
this problem is your power suply i meen logic card problem so chek your printer main logic card. chek EST or capiter.on board.
Dec 20, 2010 | Dell Laser 1720 Printer
Computer shuts down immediately after I turn it on.
First look for the obvious-make sure it's plugged in to a power source and make sure you got enough battery power. Nothing?
It immediately shuts down, because it's telling you it needs to be taken in to have the Apple dorks fix it, as this is not something that can easily be fixed on a web site. Opening this thing up with hands on fixing is required for your machine, but keep in mind that your warranty is void if you spilled water on the laptop.
Nov 02, 2010 | Apple MacBook Mac Notebook
Have a Mr. Coffee SKX12 - shuts off right after brew cycle
Sounds to me like you need to set the unit to the correct/actual time.
Apr 10, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
Bag light stays on, powers on then shuts off immediately. What is the problem?
first check to make sure there is a bag in the machine, if so make sure that its in securely, there is a pin switch in the bag door that wont allow the machine to turn on if there is no bag in it. If that's okay, then find the knob on the top of the machine ( in the middle of the canister ) and make sure its turned to the maximum, that is a sensitivity knob that can keep the machine from working ( in case it was clogged, but if its too sensitive it could think the machine is clogged when it really isn't ).
Sep 16, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Samsung washing machine won't complete cycle
If it is shutting off when its in the spin cycle than you either have a unbalanced load or a problem in the shocks that will trigger a false shut off in the spin cycle.Let me know what cycle it's shutting off in.Also if you can catch it right when it shuts off , then immediately try to turn it back on ,if it comes on without hesitation then you can rule out a failing motor .
Jul 13, 2008 | Washing Machines
Machine shuts off immediately
your ac driver could be damage or a connector is loose
Jun 18, 2008 | Canon imageRUNNER C3220 Color Copier
IBM Personal Wheelwriter 2 Logo
158 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
