Question about InFocus IN102 DLP Projector
How do I repair the power supply?
Projector totally dead.
2 Suggested Answers
projdoc
  • 2236 Answers
SOURCE: Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Posted on Sep 04, 2009
My projector comes on and is totally fine but wont show a picture i can switch inputs and go to the menu but all i get is a blue screen help?
HI
YOU NEED TO REPAIR / REPLACE THE MAIN BOARD.
THE SUPPLY TO THE LCD PANEL CIRCUIT BLOCK MAY BE DEAD.
CHECK THE POWER SOURCE TO IT .WNA200 - SHARP CHIP FOR DEAD FUNCTION.
THIS SHOULD CURE THE PROBLEM , ELSE YOU MAY HAVE TO REPLACE THE BOARD!
CHEERS!
Apr 05, 2015 | Panasonic PT-AX200U Projector
Hitachi 1350 projector dead, no power. cleaned everywhere, changed the bulb, nothing I do gets power into it.
I assume the projectors are of similar age and have similar useage history? Not certain why they would fail together, but the most probable cause is faulty switch mode power supplies. The electrolytic capacitors in these supplies a relatively short working life, especially when installed in high temperature environments - like a video projector. new caps in the supplies may be all that's required to solve the issue. If you have other similar projectors, they may well be approaching the same problem.
Any reasonably competent TV repair tech should be able to check the supplies for you, and repair them if found faulty :o)
Apr 05, 2014 | Hitachi PJTX100 Multimedia Projector
As it has become clear, there is a problem with Westinghouse SK-32H540S , burning or chemical smell. Is this an easy repair or total wash ?
What is the problems of the response of the tv?Tv power LED light indication flashes or totally dead?Or something else problems?If it is the tv power problems.The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | Westinghouse 32" Flat Panel LCD HDTV
The Unit is Pluged in But No Power is on, There are no lights on the unit. What Do I do -
The power supply is dead. I can repair these power supplies for a fee. Let me know if your interested.
Apr 19, 2010 | InFocus LP 650 Multimedia Projector
Power in cable, but projector is dead - no light, no fan.
bad power supply. you can get the part from an infocus service center, or send it to them to repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 08, 2010 | InFocus IN26 Multimedia Projector
I want to test my infocus lamp to know if it is burnt
Your lamp might be ok, but you power supply is dead. If your not seeing any led lights come on when the power cord is plugged in then your power supply is dead. I can fix this for you for less then it cost to send to infocus or to a repair shop. Ebay Id is Gtitubro
AIM - Gtitubro
Feb 12, 2009 | InFocus Lamp Projector Lamp for LP650,...
Where are the fuses in a Sharp xg-nv3xb notevision3 projector
Main line fuse is on the board where the ac cord plugs.
The caps in the power supply usually leak and explode after 5 years, blowing the fuse. Solution is to replace the power supply and lamp ballast boards. Expensive repair.
Nov 09, 2008 | Sharp Notevision PG-A10X Multimedia...
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
Hp vp6310
If you have no indicating LED, then main power supply is dead. If you have indicating LED but lamp don;t turn on, then it is either the ballast or color wheel sensor.
Aug 23, 2008 | HP VP6310 Multimedia Projector
InFocus IN102 DLP Projector Logo
74 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
