Question about Miscellaneous
Why does my Mowerland MLMC-A multi tool have no power to cutting tools when the throttle is being applied?
Was using the hedge cutting tool today fine, after a while though power just seemed to stop getting to the cutting end. I tried the chainsaw attachment and had the same problem. The motor seems to be running fine, throttle also. Just the power getting to the tool.
  • Carl Colclough May 05, 2015
    Took the thing apart and found the drive shaft had gone. Thanks guys anyway.
  • 2,760 Answers
Clutch ??
Posted on May 18, 2015
trippssmengi
  • 76 Answers
SOURCE: Long reach hedge trimmer
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
Posted on Jan 14, 2009
  • 5 Answers
SOURCE: Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Posted on Apr 15, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
Posted on May 03, 2010
dmiesner
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
Posted on May 29, 2010
  • 5 Answers
SOURCE: homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Posted on Jun 09, 2010
2005 buick lacrosse crank shaft sensor how to replace
What engine does yours have ? 3.6 or 3.8 L An when finished a
Crankshaft Position System Variation Learn
  1. Install a scan tool.
  2. Monitor the powertrain control module (PCM) for DTCs with a scan tool. If other DTCs are set, except DTC P0315, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
  3. Select the crankshaft position variation learn procedure with a scan tool.
  4. The scan tool instructs you to perform the following:
  5. 4.1.
    Accelerate to wide open throttle (WOT).
    4.2.
    Release the throttle when fuel cut-off occurs.
    4.3.
    Observe the fuel cut-off specifications for the applicable engine.
    4.4.
    The engine should not accelerate beyond the calibrated RPM value.
    4.5.
    Release the throttle immediately if the value is exceeded.
    4.6.
    Block the drive wheels.
    4.7.
    Set the parking brake.
    4.8.
    DO NOT apply the brake pedal.
    4.9.
    Cycle the ignition from OFF to ON.
    4.10.
    Apply and hold the brake pedal.
    4.11.
    Start and idle the engine.
    4.12.
    Turn the A/C OFF.
    4.13.
    The vehicle must remain in Park or Neutral.
    4.14.
    The scan tool monitors certain component signals to determine if all the conditions are met to continue with the procedure. The scan tool only displays the condition that inhibits the procedure. The scan tool monitors the following components:
    Crankshaft position (CKP) sensors activity--If there is a CKP sensor condition, refer to the applicable DTC.
    Camshaft position (CMP) signal activity--If there is a CMP signal condition, refer to the applicable DTC.
    Engine coolant temperature (ECT)--If the engine coolant temperature is not warm enough, idle the engine until the engine coolant temperature reaches the correct temperature.
  6. Enable the crankshaft position system variation learn procedure with the scan tool and perform the following:
You best bet is take to the dealer ,unless you have a GM Tech2 factory scan tool .
Oct 20, 2015 | Buick Cars & Trucks
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
Electric bushwacker trimmer wil not start
other than making sure u have a good power cord feeding it that's plugged into a known good outlet (not the one u always use) , any other troubleshooting would require u to open up the case to further investigate any faults , this maybe is a thing thats better left to an expert due to it being an outdoor electrical appliance and can adversely affect ones health and well being if something was mis done inside , any sears repair centers would sure be capable of fixing this tool and safely
Apr 08, 2014 | Craftsman Bushwacker Bush/hedge Trimmer...
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
Added throttle and cuts out
remove the muffler and run it if runs good open the muffler and clean the screen
May 21, 2012 | Oregon Scientific Complete Carburetor for...
My 91 lexus ls400 starts but cuts right off but if i tap on the accelerator it satys running anyone knows why?
Did you check the throttle/ accellerator position sensor for proper reference voltage and smooth operation? You can use a scan tool or multi-meter.
Jan 26, 2012 | Dell Computers & Internet
My Mod. 2400, type One is dull--7yrs. old. How do I sharpen it? Thank You
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results.
Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Sep 13, 2011 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
I have a Dremel model 395T6 (F013 0395 04). The other day I was using it to cut plastic. It worked fine and was turned off during operation. When turned back on for the same operation there was no sign...
Well, yes you can measure the switch, look for continuity. I suspect something else is wrong, some models had armature issues. Measure the coils and armature for continuity.
Oct 11, 2010 | Dremel 300 1/40A "Multi Pro" Rotary Tool...
Do I ever need to sharpen? If I do, how?
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
  • Work table
Tips & Warnings
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Miscellaneous Logo
196 people viewed this question
Top Miscellaneous Experts
Narinder Chhina
Narinder Chhina
extremebill
Level 1 Expert
tlaloc
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
